Harry B
posted on 9/10/05 at 07:50 PM |
Rolling chassis?
I am currently trying to build a Robin Hood Sierra 7(S7),and have got to the stage of fitting the mechanics such as front/back axles,gearbox and
engine etc. Firstly,to acheive a rolling chassis,what are ALL the parts I will need bearing in mind that I'm going to use a Sierra engine about
1500cc+/-. And where can I find these parts,preferably in a package-they do not necessarily have to be in good nick,as I can paint them, but would
prefer to buy them in a package rather than buying bits,only to find that something (eg.brakes etc.)is missing.Any help would be very much
appreciated,and please explain simply as I am a newbie(and only 17 with limited knowledge{so far}of kit car mechanics.
rayward
posted on 9/10/05 at 08:03 PM |
Hi, welcome the nuthouse,
front end you will need:
wishbones+bolts
shockers
hubs c/w discs and calipers
steering rack
track rod ends
bottom ball joints
top balljoints
new wheel bearings
wheels
rear end
diff
halfshafts
shockers
wishbones
hub carriers
hubs c/w brakes discs and calipers
wheels
bolts
thinks thats about it, don't think you'll get them in a package though either a bit at a time, or buy a donor car
Ray
serendipity123
posted on 9/10/05 at 08:04 PM |
how about
link
posted on 9/10/05 at 08:11 PM |
just buy a sierra, thats the best start, i wouldnt bother with online donor part companies, theres no need to spend that kind of money.
Is your RH a newer one? Does it have mountings for a sierra diff or is it an older design?
Harry B
posted on 9/10/05 at 08:14 PM |
It's an older design,but with Sierra mountings.I basically bought it off a guy who stripped it out to build a 2b,so alot of the parts are
missing.I am tempted by a donor,but think that stripping a donor might prove too hard to take on-where the hell do I start etc?!!!!
serendipity123
posted on 9/10/05 at 08:22 PM |
i have a hood myself, if you want some advice, sell it in ebay and either build your own or buy a chassis about £500 ready weilded
Harry B
posted on 9/10/05 at 08:24 PM |
Am going to (amazingly)stick this out until it is on the road.Just need alot of advice on what to do to get it running.How hard is it to strip down a
Sierra?
big_wasa
posted on 9/10/05 at 08:29 PM |
If you have the relivant tools you can strip the full donor in one day..At the mo you can get whats left taken away for free as the price of scrap is
high ..A Sierra will cost you £0-100 depending on spec.. Avoid the Dohc as its harder to get it, and the mt75 box in a R-hood..But it has been
done...![](/images//smilies/smile.gif)
Harry B
posted on 9/10/05 at 08:33 PM |
Very helpful-which tools are you talking about?Engine arm welder,etc. I take it as I can get those if needs be.What about getting the rear axle out-it
must be bloody hard work right?Will I need to put it up on a high rack as that may prove more difficult?
dave-69isit
posted on 9/10/05 at 09:56 PM |
chassie
were are you based mite be able to help
posted on 9/10/05 at 10:34 PM |
its really easy to strip a sierra to bits, an impact wrench is useful but not essential. just simple tools besides that. I and many others here could
tell you every single bolt involved in ANY part on the entire car.
if you're local id even help!
marshall
posted on 10/10/05 at 05:49 AM |
striping a sierra to bits is the fun part and you can get to know were the bits should go. give it a go its fun. if you are near me i can help 2
Harry B
posted on 10/10/05 at 07:03 AM |
I am based five minutes from Newmarket in Suffolk.I am planning on stripping the car probably in xmas but would love some help if anyone is near
there.
Steve Hnz
posted on 10/10/05 at 07:53 AM |
Harry, I stripped a Sierra for most of my bits, not too hard though my donor came without an engine which made it easy. Did the rest solo but help
will make it easier. Hire an engine crane to lift that out, about an hour to do this, the rest can be done with a reasonable selection of sockets
& spanners, the Sierras are totally metric as I recall. Some coil spring compressors will make removing the suspension simpler & safer. A ball
joint splitter will help here too. Some heavy duty axle stands &/or blocks of 4"x4", say 16" long, set flat side by side with
the next layer at right angles, makes for a very stable support. A pry bar or big screw driver helps to lever things apart & a good squirt of WD40
or similar on every nut & bolt you can see underneath the night b4 will make the next day easier. A selection of ice cream containers & salad
pottles or suchlike from the supermarket for putting all your nuts & bolts into will help to keep track of what goes where, label them as you go.
Really after that its just common sense & thinking it thru. Keep it all even if you think you won't need it, body & seats should be
about all that you thow away, its amazing just what you can use & this is the place to find that out, Good luck, Cheers, Steve.
paul v6
posted on 10/10/05 at 08:29 AM |
Harry,
I'm in Fordam (also 5 mins from Newmarket) I may be able to help out!
Also have a 2.9 V6 up for grabs
Paul
Harry B
posted on 10/10/05 at 09:07 AM |
Paul V6-you have u2u
posted on 10/10/05 at 05:36 PM |
to reduce the tool list, you can miss off the spring compressor. Just remove the entire strut whole (loosen the top nut when the car is on the
ground), and hammer the shocker off once the pinch bolt is fully out. The spring remains contained and can be thrown away complete.
I also manage without a ball joint splitter, use a hammer on the track rodend, and a lever or hammer on the main balljoint.
[Edited on 10/10/05 by JoelP]
