Gav
posted on 10/10/05 at 10:11 PM |
Sick of Hammerite!
Spent to night finishing the second coat of hammerite on my chassis, god damn am i sick of painting all them tubes!
Winston Todge
posted on 10/10/05 at 10:20 PM |
Did you manage to get the second coat on within around 8 to 16 hours?
Not to be a party pooper, but I've had limited success when leaving more than 12 hours inbetween coats...
Mark has some very interesting things to say in this thread...
http://www.locostbuilders.co.uk/viewthread.php?tid=23222
Well done though! Can't be a huge amount of fun painting all those tubes!
Chris.
Gav
posted on 10/10/05 at 10:29 PM |
I actually did the first coat of the front end the previous night then this morning i did the second coat and first coat of the rest, then finished of
the second coat when i got back from work.
As i said sick of hammeriting!
Danozeman
posted on 11/10/05 at 07:48 AM |
When i painted mine i got soo bored to. The worst thing is its chipped and a bit scratched so it needs doing again!!
Dan
Syd Bridge
posted on 11/10/05 at 08:12 AM |
Chassis black from my local autopaint supplier is £25/5litres, and sprayable. Whole chassis in 15 mins, with a bit of covering for 10 feet around!!
Mark Allanson
posted on 12/10/05 at 04:02 PM |
Chassis black is the ideal paint for chassis's
Funny that!!
davey
posted on 13/10/05 at 03:53 PM |
i just got mind powder coated at work
posted on 13/10/05 at 06:18 PM |
What colours do they do that in then?
caber
posted on 13/10/05 at 07:05 PM |
Chassis Black is thick sticky and ikky to apply and then get off yourself and everything else! I think it is great for the underside of Land Rovers
but it must add considerably more weight than properly applied hammerite or powder coat! I don't know what is in it but even after it is dried
if you fix something like a bracket or panel over it it seems to glue it on i.e. you need some force to remove the bit after you have taken off the
fastener, by some force I mean a 2lb ball pein hammer and a cold chisel!
Caber![](/images//smilies/shocked.gif)
wilkingj
posted on 13/10/05 at 07:33 PM |
I agree.
Hammerite (hammered finish) is better than Smoothrite.
Chassis Black is Better still.
Trailer / Chassis Black from your Local Agricultural merchant is even better...
Thick Black goo.. and Pig Piss Proof, and that is the mutts nutts... or was it the pigs porkers![](/images//smilies/bigsmile.gif)
hammerite (both sorts) are very hard and wear well if correctly applied. However, they tend to chip a bit due to the hardness.
Chassis Black is very good.
I tend to spray the underside of my cars etc with Stone Chip where I want most protection. Its softer, and is almost self healing.
Best Regards
Geoff
http://www.v8viento.co.uk
