Tangerine Scream
posted on 13/10/05 at 04:52 PM |
What does it all mean ??
Hi all
Just been presented with the emissions sheet for my tin-top and it doesn't look good. There seems to be a distinct pattern of failure but
I've no experience in the "what causes what" of emissions.
Here's what they came up with:
Fast idle petrol + catalyst
Run1
RPM: 2755
CO: 4.63 (allowed 0.3)
HC: 157 (allowed 200)
Lambda: 0.878 (allowed 0.95-1.09)
Run2
RPM: 2583
CO: 4.43 (allowed 0.3)
HC: 149 (allowed 200)
Lambda: 0.881 (allowed 0.95-1.09)
Please can someone point me in the right direction? Don't be afraid to point out the obvious!
theconrodkid
posted on 13/10/05 at 05:35 PM |
running too rich,what car is it?
who cares who wins
pass the pork pies
Tangerine Scream
posted on 13/10/05 at 05:56 PM |
It's a Land Rover Discovery MPi
theconrodkid
posted on 13/10/05 at 06:24 PM |
check the simple things first,is engine getting hot enough,check temp sensor (ohms meter reqd),air filter and lambda sensor
who cares who wins
pass the pork pies
big_wasa
posted on 13/10/05 at 06:26 PM |
Leak on the air flow meter ?
Its a common problem , but dont know more than that????
ch1ll1
posted on 13/10/05 at 06:32 PM |
well your lamda sensor
hc passed no probs
so all you have to worry about is your CO reading !
first start of with some fuel injector cleaner, air filter,try to remove your lamda sensor and clean it, (spray it with carb cleaner), also check to
make sure your exhaust isnt blowing any where!
even the tinyist wisper will make your CO level high,
if that fails then would consider changing the cat converter (last choice!)
but do check for any small leak in the exhaust system
take it for a good run (thrash it a little and try to hold the revs up in each gear to get the cat warm) 5 to 10 miles if poss !
then try the emmision test again
hope that helps
cheers paul
p.s keep us informed of the results
[Edited on 13/10/05 by ch1ll1]
Tangerine Scream
posted on 13/10/05 at 06:48 PM |
Cheers for the pointers guys!
Will have a good check of everything you've mentioned in the morning! Too dark now
Even though I haven't found the cause, having a few pointers from the forum is enough to guarantee a more peaceful nights sleep
Luckily my Locost is "visible smoke only"
but then again...If it wasn't I may have learnt a little about emissions!
Cheers all
pbura
posted on 13/10/05 at 06:52 PM |
Check your plugs to see if you have fouling in a cylinder or two, or if the problem is generalized. A local problem will most likely be ignition.
How's the engine run?
Pete
posted on 13/10/05 at 06:56 PM |
Lambda sensor -- they get slow with age nothing youcan do to put it right but this might not be the problem.
Discovery MPi thats the 134 bhp 2 litre T16 from the Rover 820Sli with a Rover-Motorola Mems ECU.
The engine is running very rich so my first suspect would be the coolant temperature sensor, it could also be an ECU earth problem Rover cars of the
period were prone the main earth point for the ECU not giving a good earth.
However with these early MEMS ECU the MAP sensor is mounted within the ECU and conected by a long capilary tube --- first thing to do is very
carefully (nb the pipe fitting on the ECU is fragile and gets more brittle with age) remove the tube at both ends and blow it through -- often the
vapour trap i the pipe will be full of fuel and gunge.
Next check the Lambda sensor heating element is working --- and put a digital voltmeter or better oscilloscope on the signal wires to see if the are
rapidly "switching" up and down the voltage range.
Note if you do decide to replace the Lambda probe it has to be the correct 4-wire Zirconia oxygen sensor type see
http://www.gendan.co.uk/oxygen_sensors.php?manufacturer=Land%20Rover
Also because Land-Rover sold to the US market your Disco might have a standard OBD2 ISO2 connector for diagnostics.
[Edited on 13/10/05 by britishtrident]
posted on 13/10/05 at 07:36 PM |
" Well your lambda sensor passed " . Afraid not , should be between 0.95 and 1.09 . 0.881 is well out . Check items already suggested
starting with the simple/cheap ones. Best of luck
ch1ll1
posted on 13/10/05 at 08:19 PM |
PLEASE TAKE NOTICE OF THE LAST SECTION
Basic fault finding for advanced emission test failures:
If a vehicle fails for high CO at idle and /or fast idle then.... if Lambda is too low, the mixture is too rich. This can be caused either by a
misfire or by a faulty Lambda sensor. If it's running very rich, the 02 and HC will be higher than normal.
if it has a high Lambda and high 02 (0.5 to 1.5%), the "CAT" could be faulty. Before condemning it make sure its hot enough to work, the
Lambda and other sensors are working OK and the exhaust downpipe hasn't got any leaks.
if the vehicle fails for high HC then ...if the CO passes, the vehicle is probably misfiring. Or if the CO fails and the Lambda reading is too low,
the mixture is probably too rich and it may also be misfiring.
if the CO fails, the Lambda reading is high and the O2 reading is high (0.5 to 1.5%) the "CAT" could be faulty. Again check out the simple
measures above before condemning it.
if the Lambda fails then...if its too high the Lambda sensor may be faulty, the mixture may be too weak or there may be a hole in the exhaust
downpipe. If Lambda is too low the sensor may be faulty, the mixture may be rich or the vehicle may be misfiring.
alittle
Tangerine Scream
posted on 14/10/05 at 11:48 AM |
All pointers duly noted...thanks to all
The level of knowledge (and the detail!) on the forum never ceases to amaze!
Just been informed I'm working away from home till feb, so I'm going to SORN it and sort out the emissions next year. There was a few more
failure points that, although the parts are very cheap, I just don't have time now to do the work.
At least I'll have time to spam up on the subject.
Once again, many thanks
posted on 14/10/05 at 03:21 PM |
Not on the MPi it dosen't have one.
Keeping up with what engines are fitted in exactly what models is a a lottery these days :-)
The MAF sensor is really big problem but with the BMW Diesel engined LandRovers/MG-Rovers/BMW.
The test for a belly up MAF on a BMW diesel is simply to disconnect it with the engine stopped -- restart and if the engine pulls a lot better and
uses less fuel the MAF is dead or dying.
[Edited on 14/10/05 by britishtrident]
posted on 14/10/05 at 03:25 PM |
One thing I forgot to mention was the thermostat --- they get "colder" with age stick in a new 88c degree one -- Halfrauds will try to
sell you an 83 but should be an 88c same type as the Mini, Ford Xflow
