dom7
posted on 17/10/05 at 10:58 AM |
headlights adjustment
for the SVA have the headlights to be adjusted, or do they only have to work properly ?
mookaloid
posted on 17/10/05 at 11:07 AM |
They have to adjusted properly also.
Kissy
posted on 17/10/05 at 11:36 AM |
...but you'll have an MOT by then anyway, which will check the beam - only dip is checked IIRC.
posted on 17/10/05 at 11:40 AM |
Dom7. It's quite easy to do this by yourself. Use your tintop and shine lights onto a garage door or wall. Mark the beam pattern using pieces of
tape and then replicate this pattern by adjusting headlights on Indy.
Note. This is assuming your tintop headlights are already set correctly
[Edited on 17-10-05 by Hellfire]
DarrenW
posted on 17/10/05 at 12:00 PM |
Why will he have MOT by then? Its a good idea but not essential.
Hellfire - does the height difference between tintop and locost matter or do you just drop all of the marks down by the difference??
posted on 17/10/05 at 05:49 PM |
Just a thought , have you fitted British type head lights that dip to the left? You will need them to get through SVA.
posted on 17/10/05 at 09:29 PM |
Unless you have a large 4x4 or something similar you'll probably find the height difference of headlights is negligible. We just set them to the
same level and passed MOT without problems.
Bear in mind there must be min and max parameters for headlights because on most modern cars the pattern can be adjusted/altered dependent on the load
of your vehicle.
dom7
posted on 18/10/05 at 11:12 AM |
Yes , Rusty Nuts, I bought some at Lolocost 3 years ago
![](/galpreviews/a270184-head lamp 1.jpg) ![Rescued attachment head lamp 1.jpg](/gallery/a270184-head lamp 1.jpg) Rescued attachment head lamp 1.jpg
