kevano
posted on 18/10/05 at 06:19 PM |
elvington this weekend
hey hellfire and guys, you mentioned going to elvington this saturday, can't make this one but when will there be another one atfer this, how
much is it usually and what noise level? cheers kev
PAUL FISHER
posted on 18/10/05 at 09:17 PM |
£95 for the day,and 105db static test,you will easily pass that kevin with a your current set up.
posted on 19/10/05 at 01:06 AM |
If we get our currently too loud exhaust sorted (111Db) we'll be on-track. Currently looking at a new can from MK Engineering - I noticed
he's just back from his honeymoon today (Tuesday). I know Martin is going to Elvington also but not on track - I'm assuming! I just hope
he's not too knackered to make us one up quick!
posted on 19/10/05 at 07:39 AM |
im paranoid about my can too. Is there any temporary way i could make it quieter? stuff a rag down the end?! I cant be arsed getting there and
missing out on the fun
PAUL FISHER
posted on 19/10/05 at 09:17 AM |
You could make a temporary noise killer out of a bit of threaded rod,rapped tightly in wire wool,then bend the threaded rod back on itself to hold the
wool in place,make it just less than the diameter of the bore of the centre tube of the silencer,then if you have problems you can just remove your
silencer and slide it in, I have tried it and it was very effective in reducing noise,and is cheap to do,but having said all that,I would not worry
too much about that joel,you have got to be realy noisey at elvington to get removed from the track,its just nice to have a back up just in case
uklee70
posted on 19/10/05 at 10:08 AM |
Hi when I had this problem with the Mini
I used a road legal bike can to do the job.
If you have time just weld a bend on the end to stop it pointing at your wheel arch.
These are pennys on ebay as a temp fix
It's good to hear Martin is back but please everyone stop bugging him because he is building my car!!!!!
If there is a few of you there I'll come and have a look as I'm missing the R1 mini
Thanks Lee
Mad Dave
posted on 19/10/05 at 10:46 AM |
Check out the attendees here
chrisg
posted on 19/10/05 at 11:11 AM |
I'm going with Tony S, see you all there!
Chris
kevano
posted on 19/10/05 at 04:54 PM |
anyone going on the 30th october???
posted on 19/10/05 at 05:14 PM |
30th is the drag day isnt it? i think my mate mentioned it.
mattpilmoor
posted on 24/10/05 at 08:48 AM |
Cheers for the look around your car at the weekend Joel. It turned out we were only at Elvington for about ten minutes before dissapearing off to have
a look around a Dax with turbo busa engine. Amazing
Measure twice - Cut once - Still f*!K it up!
