posted on 27/10/05 at 08:04 PM |
fuel pipe i.d. adapters
hi all.
My old fuel pipe is 6mm internal diameter, but my new fuel pump has 10mm terminals. Do motor factors usually sell the adapters i will need, or should
i get an order in online? Been looking on the nf auto site, its about £1.75 each.
Any help appreciated
tks
posted on 27/10/05 at 08:19 PM |
mhh..
I just use an piece of rubber fuel hose....
Heat it up..an bit and it will nicely fit.
the fuel pipe external will be or 8..
use then 8mm fuel hose..
Tks
posted on 27/10/05 at 10:11 PM |
not really an option for me that one, as its 6mm all the way to the engine and its partly full of fuel, so i cant heat it. Im only changing the pump!
cheers anyway
NS Dev
posted on 27/10/05 at 10:24 PM |
I'd lob a bot of brass bar in the lathe and knock one up, d'ya have a lathe not to afr away?
stevebubs
posted on 27/10/05 at 10:54 PM |
If you want a pucker adapter then you're probably best off asking in a motorsport place.
Alternatively you can bodge one up if you think about it hard enough...
![](/images//smilies/cool.gif)
gutball
posted on 27/10/05 at 11:10 PM |
Joel, I think what tks means is get a short length of rubber fuel hose to fit your pipe ( ), warm one end, dip one it in some freshly boiled water
for 30 secs or so (ouch!), hopefully that'll make it flexible enough to squeeze over the pump fittings.
[Edited on 27/10/05 by gutball]
