Author: Subject: Is this the right way to set up front suspension?
ditchlewis
posted on 1/11/05 at 05:17 PM Reply With Quote
I am just about to set up the front suspension on my car and just wanted to run my method past the experts first. May be there is an easier way?
I am using a sierra donor with the mushroom insert.
First I was going to jack up the front and using a “C” spanner to adjust the ride height, in creasing it about an inch.
Then I was going to drop the car back onto it wheels and using the vertical split in the back of the upright and a 15cm length of timber measure how many mm out of plum it is (6mm approx = 1degree).
I will than jack the car up and using the “C” spanner adjust the mushroom insert and replace the wheels.
Once the car has been dropped I will measure the difference between the top and bottom of the wheel and thus the camber. Removing the wheels again I will then adjust the top ball joint to the required length to give 1 degree approx of camber.
The toe out will be set using the string method described in an earlier thread.
Is this the right sequence and method or have I got it all wrong?
Many thanks
posted on 1/11/05 at 05:42 PM Reply With Quote
just a little query, should that picture say castor at the top? And if you are measuring castor from a casting line/slit etc, are you sure it is vertical or in line with the tapers, as required?
ditchlewis
posted on 1/11/05 at 08:49 PM Reply With Quote
oops yes that should read castor.....
the split is part of the casting to allow for the removal and replacement of the donor sierra upright from the hub. on the sierra this was in the vertical with the front strut, so i assume it is the best method of measuring verticallity. Is there another way?
ditch
posted on 1/11/05 at 09:03 PM Reply With Quote
not thought about it myself, just thought id make sure you did! Remember that this part, though perpendicular to the strut, might not be in line with the two ball joints. Good luck, but remember that you will always get best setup if you take it to a pro anyway, who can use expensive machinery and experience to get everything spot on
givemethebighammer
posted on 1/11/05 at 09:16 PM Reply With Quote
I don't know Joel, I did a pretty good job with a camber gauge (ebay bargain), gunson's trakrite toe gauge and a bit of patience
I managed to set the front camber \ caster \ toe and the rear camber \ toe.
car handles very well so can't be far out.
This is not what I have but could be OK
http://cgi.ebay.co.uk/Camber-Gauge-Magnetic-Sealey_W0QQitemZ8009782523QQcategoryZ30917QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
[Edited on 1/11/05 by givemethebighammer]
posted on 1/11/05 at 09:22 PM Reply With Quote
i know what you are saying mate but mine feels glued down too even though the toe doesnt even look right! I think it feels great just because its so nimble, Jon Ison got his setup professionally (think it was him anyway) and was very happy with the results.
[Edited on 1/11/05 by JoelP]
ditchlewis
posted on 2/11/05 at 10:29 AM Reply With Quote
Many thanks
I just want to get the car in a safe predictable state. the problem that i have is that the brackets for the front wings are identical and handed, they are located into the hub by the slot in the hub and the bottom ball joint. they position on the hubs indintically (same measurements from brake bolts etc) but as viewed accross the car they are both at a different angles. I think that this would indicate that the castor is out? (see attached pic)
I agree and i will get a pro to set it up after the SVA, but i want the brackets to line up so i can fit the wings.
regards
blueshift
posted on 2/11/05 at 08:59 PM Reply With Quote
Or your wing brackets aren't identical / aren't identically mounted to the uprights. I wouldn't set up your castor by going off the cycle wings.
grusks
posted on 2/11/05 at 10:39 PM Reply With Quote
I've all ways found this type of gauge spot on. hold it against the wheel and read away.
You can make your own with a bit of ali bent at 90`and pertractor and a bit of string etc.
Need More Money
posted on 3/11/05 at 11:50 AM Reply With Quote
The important thing is to get the car at its working laden ride height (for a Locost this is normal one up ie driver only )--- one way of doing this is to make 4 setup blocks to fit under the chassis is to screw the springs down untill the chassis just rest on the blocks.
I have always found the price of the equipment used is inverse proportion to the brain power of the guy using it.
The most valuable tool when setting a car up is a truly level floor to use as a datum.
The trackrite is probably one of the most accurate methodd of setting toe-in across the axle. Set the toe as close as posible for each wheel using string methods then set the overall toe with a trackrite or if you ar lucky enough a Dunlop Optictal tracking beam.
Likewise camber --- which isn't super critical anyway as long as it is in the right ball park is best set with fairly simple tools that use either a plumb line or spirit level.
Caster is the really tricky one it isn't easy measure directly and the important bit to get equal both sides.
givemethebighammer
posted on 3/11/05 at 10:03 PM Reply With Quote
the camber gauge I used is the same as the one grusks posted. It came with a set of instructions for measuring the caster, involved measuring the camber of the wheel at different positions through the movement of the steering. A bit of simple maths (also explained with the gauge) and you have a caster figure. The trakrite is a breeze to use. Only downside is that you have to take it apart and clean it fairly often as the grit from the tyres gets in the rollers and affects it's operation.
