rich201283
posted on 14/11/05 at 10:45 PM |
dgas carb on 1.8 zetec
If i put a dgas carb on an 1.8 zetec do you think there would be any performance gains? I have drove a 2 ltr pinto, do you think it would be as quick?
stevebubs
posted on 15/11/05 at 12:14 AM |
performance gains over what?
Seen a DGAS has been fitted to a zetec-engined Anglia but only because the builder was going as simple and cheap as possible.
Think the manifold was based on a CVH one
rich201283
posted on 15/11/05 at 07:37 AM |
does anyone know if a crossflow manifold is big enough
rayward
posted on 15/11/05 at 11:29 AM |
if you mean to fit on the zetec, no the inlet ports are different spacing(100mm/80mm) i think
Ray
auzziejim
posted on 15/11/05 at 06:54 PM |
to fit a DGAS to a zetec you will need a CVH inlet manifold and make up an adaptor plate to bolt to the block first.
i have the same setup in my mk2 escort running a 1600 zetec and 32/36 DGAV
performance with the DGAS on an 1800 should be reasonable but not too much over the standard injection
rich201283
posted on 15/11/05 at 10:41 PM |
Have you got any pics of adapter plates to give me some ideas?
stevebubs
posted on 15/11/05 at 11:07 PM |
I'm sure if you do a search for zetec turbo then several will turn up.
A common Zetec turbo install to use a CVH RS Turbo inlet manifold....
