matt12
posted on 18/11/05 at 11:37 AM |
would this make a good doner
by good i mean does it have most of the parts i need , i really hope it does because its ten minutes down the road from where i plan to build the
car.
FORD SIERRA 1.8 1992
manual transmission
1992 J REG FORD SIERRA 1.8 CLASSING THIS AS SPARES OR REPAIRS DUE TO SLIGHT OVER HEATING PROBLEM
NEW BATTERY,STARTER MOTOR,FRONT BRAKES (DISCS AND PADS) RECONDITIONED ENGINE FITTED
thats all advert says, its on 65 quid at mo but prob go up a bit
[Edited on 18/11/05 by matt12]
ditchlewis
posted on 18/11/05 at 11:58 AM |
Depends upon what you are building ?
It would make a good donor for any number of the kits, but would require you to change to book chassis to get it to work.
ditch
BKLOCO
posted on 18/11/05 at 12:12 PM |
Be aware this will not be a Pinto.
1.8 CVH is what it will have in it.
An OK engine that does not respond well to tuning.
1.6 CVH is a better engine if you intend to "tweak" it.
2.0 Pinto best if you can find one.
(like the one in my shed!!!!)
Rest of bits will depend on what chassis you are going to use.... book or one built to accept sierra running gear.
This would make an ideal donor for say a GTS.
matt12
posted on 18/11/05 at 01:07 PM |
i intend to build the car myself like the book , im aware one of the kit car firms , cant remember which one sells plans for a book style chassis, but
adapted for seirra parts, in terms of that would the other parts on this be suitable?
would i be able to use the gear box and diff and a different engine or would i have to get a different engine and diff. im not really bothered about
massive performance because i have my motorbike to get my speed thrills with
scotty g
posted on 18/11/05 at 01:13 PM |
SLIGHT OVER HEATING PROBLEM, roughly translated this means that the head gaskets gone, quite a common problem on the 1.8 CVH but you get the type9
gear box with it so you can bung in a pinto or zetec or just about whatever you want as most bolt on to the T9 box with an adaptor bellhousing.
matt12
posted on 18/11/05 at 01:43 PM |
it wouldn't be a problem to wack on a new headgasket, how much would a be looking at for a pinto ?
i'll be using gts plans for chassis
the main appeal of this car apart from it being a seirra is its ten minutes from where i plan to build the car unlike the others which i have found
which are miles away
BKLOCO
posted on 18/11/05 at 01:46 PM |
from what you say then it's probably worth getting at a sensible price.
You will probably be able to use:
Engine?
G-Box
Dif,
Drive shafts and hubs
Stearing column
steering uprights (modified)
Brakes Wheel end and possibly master cylinder
Some of the wiring
Handbrake
Header tank?
If you estimate how much this lot would cost you from a scrappy you will get an idea of what your max bid should be.
Good luck.
I paid 39 quid for my donor![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
2.0 litre pinto estate, off e-bay.
They are still around if you are prepared to wait.
By the way GTS Tuning do chassis plans that use the Sierra running gear £10 a set. Several people on here using them.
matt12
posted on 18/11/05 at 01:52 PM |
it sounds like worth going for its on 62 quid though with 2 days to go so i reckon it might jump up a bit i dont want to pay more than hundred
though
is there any reason not to use the 1.8 CVH engine apart from performance ie size
ditchlewis
posted on 18/11/05 at 04:03 PM |
I paid £75 for my donor from a breakers and that includes him coming and collecting the shell after all the parts had been removed.
the car just had been brought in after failing its mot and was a good runner.
ditch
Memphis Twin
posted on 18/11/05 at 04:54 PM |
"is there any reason not to use the 1.8 CVH engine apart from performance ie size?"
It's not a bad engine, but the extra 200cc over the 1600 was achieved by offset grinding the 1600 crankpins by a very large amount. IIRC the
1600 has 48mm journals, wheras the 1800 has 40mm which makes it inherently weak for tuning purposes. If you keep a sensible rev. limit of say 6500 I
dont think you'll have a problem. The head responds to porting like any CVH, and because it's alloy it's something that you can do
youself quite easily. Valve sizes are already quite large at (from memory) 42mm inlet.
So with a high- torque aftermarket camshaft , some porting and decent rev limiter you could have a nice fast-road engine that doesn't cost the
earth.
Cheers Memphis.
