Author: Subject: 4 age ECU
Fat Boy
posted on 19/11/05 at 09:43 PM Reply With Quote
4 age ECU
Hi Guys,
Has anybody used a standerd Toyota ECU and if so could you help me with the wiring of it please,
[Edited on 19/11/05 by Fat Boy]
rayward
posted on 19/11/05 at 11:30 PM Reply With Quote
HI,
i am helping with the conversion fro a standard 4age to megasquirt at the moment, if you can let me know what your after running i may be able to help
Ray
DEAN C.
posted on 20/11/05 at 12:49 AM Reply With Quote
Yes I've used the standard ecu on a TVIS set up,there are a couple of different types of ecu mainly non TVIS and TVIS engine variants.
My advice is use the original engine loom,bin the fuse box from the Toyota and use your own and wire your ecu into the engine loom using the Toyota manual for the pin locations on the plugs into the ecu.
Hope this makes sense,if you need any help just let me know what you are not sure about. It looks complicated but its not too bad really,youll end up with a cheap set up and smooth reliable running.
Regards Dean.
PS. Look in my photo archive for how I did mine : MK Indy 004.jpg (electrickery)
[Edited on 20/11/05 by DEAN C.]
Once I've finished a project why do I start another?
albertz
posted on 20/11/05 at 07:32 AM Reply With Quote
I agree with Dean C above, try to get the complete loom etc from the donor and reinstall as original, then when running chop out unnecessary bits and tidy up.
I had a nightmare doing mine, but got there in the end.
Fat Boy
posted on 20/11/05 at 02:40 PM Reply With Quote
Thanks Guys,do you have the pin outs to live up the ecu in to my car loom,the car loom is new and the engine loom is the standerd toyota one as you said,all I need is the pin outs for the toyota loom at ecu to get my car runing.
DEAN C.
posted on 20/11/05 at 04:25 PM Reply With Quote
Which engine is yours(TVIS or Non TVIS)?
And which ecu plug configuration is it,ie there should be three plugs with how many pins in each plug?
I have the Toyota workshop manual pin outs which is the easiest to follow,I just need to know which plug config. the ecu has.
Dean.
Fat Boy
posted on 20/11/05 at 04:31 PM Reply With Quote
Dean you u2u thanks
DEAN C.
posted on 20/11/05 at 07:13 PM Reply With Quote
If you look in my photo archive I have just uploaded a pic of the ecu pin outs for the TVIS without air flow meter.
Its a bit large but its the only way I could keep the fine detail.
