Author: Subject: what engine is this?
rayward
posted on 29/11/05 at 12:47 PM Reply With Quote
any ideas what is was originally fitted to, and what gearbox would fit?
answers on a postcard.....
or here
Ray
rsk289locost
Junior Builder
Posts 61
Registered 24/5/05
Member Is Offline
Photo Archive Go!
Building: Resurrecting, slowly, a 289 Cobra I built years ag
posted on 29/11/05 at 12:50 PM Reply With Quote
Mk 4 or 5 (not sure) RS2000 same as I4 but with 16 valves. 150 BHP ish.
flak monkey
posted on 29/11/05 at 12:52 PM Reply With Quote
Looks like an I4 indeedy. Heres a bit of pinched text from another site:
Engine
RS2000 I4 EngineAt the time other Mk5 Escort were still using CVH engines because the new Zetec 16 valve engines were not introduced until 1992. Instead of using CVH , Ford chose the 'I4' 8 valve DOHC engine used in the Sierra and Scorpio as the base for the RS2000 engine. Fitted with a new Ford developed 16 valve head this engine produced 150hp. As opposite to other Ford overhead cam engines, this engine used chain driven camshafts. Tubular exhaust manifold was quite good design when compared to usual Ford cast iron manifolds.
* DOHC 16v, iron block, alloy cylinder head.
* Bore and stroke 86,00 x 86,00 mm , 1998 cc, compression ratio 10,3:1.
* Electronic fuel injection, Ford EEC IV engine management system.
* Max power 150 hp at 6000 rpm, max torque 190 Nm at 4500 rpm.
Here it is at home:
As with all ford engines it will mate up to a type 9 gearbox as the bolt pattern on them all is the same. You will prob need a different clutch though.
[Edited on 29/11/05 by flak monkey]
Sera
http://www.motosera.com
Schrodinger
posted on 29/11/05 at 12:55 PM Reply With Quote
I don't think that the Duratec will fit onto a type 9 gearbox.
The engine code should tell you what it came from
regards
Keith
Suffolk
ned
posted on 29/11/05 at 01:03 PM Reply With Quote
regards
Keith
Suffolk
i'm pretty sure the engine inquestion is not a duratec, its a dohc with a 16v head.
based on the dohc block it should fit upto a type 9 without too many probs.
Ned.
beware, I've got yellow skin
flak monkey
posted on 29/11/05 at 01:06 PM Reply With Quote
Ned.
Yup. As the italics bit in my post says. The I4 was based on the old DOHC as used in sierras and scorpios etc. But it has a 16V head on.
I4 was pre-duratec and zetec (pre 1992)
Sera
ned
posted on 29/11/05 at 01:15 PM Reply With Quote
sorry t0 be pedantic, but my understanding is that i4 is not an engine code or identifier it is simply the layout of the engine and was sued to differentiate the duratec i4 and v6 engines. people seem to use it somewhat confusdely to describe other non duratec engines, the rs2000 engine is just that, an rs2000 16v, based on the block of a 2ltr dohc 8v.
Ned.
rayward
posted on 29/11/05 at 01:17 PM Reply With Quote
okey dokey, now i know what it is, any good??
Ray
theconrodkid
posted on 29/11/05 at 01:38 PM Reply With Quote
in a word nope
who cares who wins
pass the pork pies
posted on 29/11/05 at 01:44 PM Reply With Quote
Not a bad engine if it's in good nick and cheap/free, but will suffer from the same problems as the Sierra DOHC, very heavy, very tall and expensive to work on.
theconrodkid
posted on 29/11/05 at 01:46 PM Reply With Quote
not to mention the burnt out valves,the rattles,the dodgy timing chain and was it mentioned it weighs as much as a small planet
who cares who wins
pass the pork pies
stevebubs
posted on 29/11/05 at 01:56 PM Reply With Quote
Ned.
Yep....
i4 = inline 4
The engine pictured is normally referred to as the Ford DOHC and should not be confused with any zetec or duratec variants.
NS Dev
or here
Ray
All the answers so far are close but no cigar!!
It is the same block and head as the Late RS 2000 engine, but it is from a late 16v scorpio, as you can see that it is RWD and has sierra type engine mounts attached to it, which will definitely not fit a fwd escort!!!
It was available in 2.0 and 2.3 ltr formats and is a very good, though rather heavy engine.
NS Dev
posted on 29/11/05 at 01:58 PM Reply With Quote
Oh yes, meant to say, MT75 (ex 2ltr twin cam 8v sierra one) 'box bolts straight on.
scotty g
posted on 29/11/05 at 02:52 PM Reply With Quote
Interesting, does anyone know the power levels from the 2.3 version?
NS Dev
posted on 29/11/05 at 02:59 PM Reply With Quote
no, but not a whole lot more than the 2.0 in std form, but then the std 2.0 is 150 hp anyway so not too shoddy!
Mr G
posted on 29/11/05 at 04:39 PM Reply With Quote
Graceland (Paul) on this forum made his own manifold and turbo'd one after putting it in his sierra. He took it out to put in his build. Original thread was over at inter-ford.
PAUL'S BUILD DIARY
G
jon_boy
posted on 29/11/05 at 05:03 PM Reply With Quote
tey going to feoc.co.uk. a lot of people put these engines into escorts or use the 2.3l variants from galaxies although some mods are needed for that. Lot of torque for not much tuning is what i hear but big bucks for big bhp.
AvonBelgium
posted on 30/11/05 at 11:07 AM Reply With Quote
This engine comes from a late scorpio.
It is a 2.0 (see valve cover) and has 136 BHP.
It fits streat on a MT 75 or T9.
It weight 130 kg net.
I use a RS 2000 engine ( same but different cames) with self made carbon fibre intake manifold, shortend sump from a sierra DOHC.
scotty g
posted on 30/11/05 at 12:59 PM Reply With Quote
Hi Avonbelgium, i will need to shorten the sump on my DOHC, any hints, tips or even pictures you can share????
Cheers. Scotty G.
AvonBelgium
posted on 30/11/05 at 11:58 PM Reply With Quote
http://www.cr-modelltechnik.de/bgstart.htm
Try this link.
It is the site from a German Rush builder.
It is only in German, but the pictures will speak for themself.
I built mine in the same way
jon_boy
posted on 1/12/05 at 02:46 PM Reply With Quote
In 1989 ford introduced a new iron blocked range of engines as replacement for pintos. this was shorter, squatter and more rigid in design with an ally cylinder head. originally 8 vlave chain driven twin camwith fuel injection managed 125bhp. An evolution complete with new narrow angle 16v twin cam cylinder head then appeared in the rs2000. Solely used by the rs2000 and later by the scorpios and galaxy's although slightly detuned and refined also including twin balancer shafts mounted in the sump. F2 rally experience showed it could be tuned to produce at least 282 bhp non turbo with a very borad torque curve. mxt75 five speed manual box.
scotty g
posted on 1/12/05 at 05:27 PM Reply With Quote
I deffinately want to use my DOHC but having seen one with a standard sump fitted into a Dax Rush i know i will need to get the sump shortened but i hear its not any good to weld it and i don't know anyone who sells them already shortened.
Any suggestions?
