RichardK
posted on 4/12/05 at 10:41 AM |
Clutch Alignment Tool
Is anyone selling one for a post 84 sierra (91 pinto) or can lend me it for a while.
Rich
Gallery updated 11/01/2011
clbarclay
posted on 4/12/05 at 11:06 AM |
If you can't get your hands on a propper one then there are more locost options. 1 is to find a lath and make one up your self (worked for me in
the past).
Option 2 is to get a a tube (or bar) that fits inside the the flywheel bearing (a preferable as closer fit as is possible) and the wind duct tape
round the tube in the right places so that the tape forms the correct profile for alligning the clutch. This methoud has also worked for me in the
past.
Danozeman
posted on 4/12/05 at 11:07 AM |
Get something like this mate.
If u have a partco unipart near you they sell them for 7 quid.
A cheaper way, if u can get your fingers under the pressure plate enough to be able to feel the friction plate. U can feel it in and move it with a
screwdriver through the centre. Centralise it as u tighten it up.
[Edited on 4/12/05 by Danozeman]
Dan
Russ-Turner
posted on 4/12/05 at 11:08 AM |
I picked up this exact same type last week and i'm v. pleased with it. I think it will do anything but a Mini. I payed by cheque and it still
arrived in a couple of days.
LINK
[Edited on 4/12/05 by Russ-Turner]
posted on 4/12/05 at 11:10 AM |
Masking tape round a socket bar works. I've used one of
these for the last 10
years without any problem, mine was about £3 when I got it.
MikeR
posted on 4/12/05 at 12:14 PM |
i've used the cheap tool in the past - its great, can't fault it at all!
jollygreengiant
posted on 4/12/05 at 04:16 PM |
simple locost fix is to nick the input shaft from a broken gearbox. guaranteed fit every time.![](/images//smilies/bigsmile.gif)
If you have a good selection of sockets (3/8" and 1/4" and extensions you can make up to fit almost anything.
jonbeedle
posted on 4/12/05 at 07:28 PM |
Always used a marker pen. It's just the right diameter for Escort gearbox, don't know about Sierra though!
Jon
"Everyone is entitled to an opinion however stupid!"
davey
posted on 5/12/05 at 10:14 AM |
BROOM HANDLE
andyharding
posted on 5/12/05 at 10:25 AM |
Don't need one. Do it by eye. You will get it close enough the splines will go in but not the spigot. Loose fit the bolts and press the clutch
pedal and everything will drop into place.
