Author: Subject: Attaching PW loom to column controls
richyo
posted on 19/12/05 at 10:18 AM Reply With Quote
As the title says, whats the best way to attach my Premier loom to the wires from the column switches.
Is it just a case of splicing them together using suitably rated spade connecters ?
TIA
Richyo
zxrlocost
posted on 19/12/05 at 10:23 AM Reply With Quote
the best way to wire anything that your planning on not really messing with again
is to solder and use heat shrink
much neater and less crap everywhere
chris
Danozeman
posted on 19/12/05 at 12:17 PM Reply With Quote
Yep solder and heat shrink if your not planning to have it off again.
You can twist it all together to make sure it works ok then solder afterwards. Much neater.
Dan
rusty
posted on 19/12/05 at 01:42 PM Reply With Quote
Soldering also suffers less from corosion problems unlike crimp connectors.
If you do wish to beable to unplug then get an apropreate multi way plug then you can unplug all in one go much tidier
posted on 19/12/05 at 06:29 PM Reply With Quote
A bit late now but Premier will attach Sierra multi plugs to the loom if you send them the multiplugs from your donor with the order , also you need to tell them which switch's you are using . Anyone thinking of using one of their looms take note
