jestre
posted on 3/1/06 at 06:01 PM |
Differend Idea for adjustable wishbones
-=too much horsepower is just enough=-
posted on 3/1/06 at 06:11 PM |
very nice , but perhaps not so "locost"
jestre
posted on 3/1/06 at 06:25 PM |
Nope, found them on a 350Z/G35 racing parts site. for $895
blueshift
posted on 3/1/06 at 06:26 PM |
They look pretty, but heavy and inelegant design. in my opinion.
I don't get quite how the adjuster works, it looks like it's just friction clamped, but that strikes me as daft.
jestre
posted on 3/1/06 at 06:36 PM |
to quote the website
quote: This G35 camber adjustable front control a-arm kit allows for complete camber adjustment of the G35 front suspension. The sliding camber plate
design makes camber adjustments quick and easy using just a 13mm wrench. No suspension disassembly is required to change or fine tune your G35's
camber. These G35 suspension arms are made from CNC machined aircraft aluminum using a sliding camber plate with mono-ball design. The G35 control
arms even come powder coated against corrosion. This G35 suspension kit is complete with the mono-ball that fits in the OEM G35 upright and the
spherical bearings that mount to the chassis. Using the mono ball and spherical bearings make the suspension move freely which results in crisper
steering. This is the G35 suspension of choice in G35 racing applications and we recommended them for any lowered G35. The sliding camber plate design
is so strong that the 350Z race cars in Grand-Am Cup have bent rims without loosing their camber setting!
mak
posted on 3/1/06 at 07:16 PM |
Well if they can afford a carbon-fibre work bench they can afford anything! javascript:icon(''
posted on 3/1/06 at 07:42 PM |
not very impressed -- goes to prove you can charge what you want for car bits if they look techie.
posted on 3/1/06 at 08:49 PM |
You can get exactly the same type of upper wishbone for Honda Civics, and they also rely on friction to hold the ball joint in place. In the Honda
and (I think) the 350 the upper wishbone is quite a distance from the hub, which minimises the force is sees.
That is a very inelegant design though, the arms of the wishbone are nearly parallel, so it's placing almost pure bending force on these members
rather than the tensile/compressive force of a triangulated wishbone.
[Edited on 3/1/06 by MikeRJ]
NS Dev
posted on 4/1/06 at 08:37 AM |
The friction clamp arrangement will be absolutely fine.
If you are worried about that then you'd better not look too closely at many other things on cars!!........take many camshafts for example, take
the Zetec engine, cams with no keys, just the friction from the centrebolt holds the pulleys in relation to the cams.......don't worry about
clamped fits!
The wishbone does look pretty crap though! Loads of material doing nothing and none where it needs to be!
quattromike
posted on 4/1/06 at 06:39 PM |
Also I don't think you could be very accurate with the adjustment, just slacken off a bit and hit with a hammer to move it!
Mike
[Edited on 4/1/06 by quattromike]
NS Dev
posted on 4/1/06 at 09:36 PM |
aha, it's ok, you need the highly technical tool known as a "podger"
Tapered punch type lever bar!
gazza285
posted on 4/1/06 at 09:42 PM |
A podger is a spanner with a long, tapered point on the end.
I think you possibly mean a heel bar.
gazza285
posted on 4/1/06 at 09:43 PM |
Just being pedantic (it's a hobby of mine, the wife says).
