Author: Subject: wiring
mat.price
posted on 3/1/06 at 06:54 PM Reply With Quote
wiring
Can anyone help on the Avon wiring?
I am having trouble finding the master cylinder brake connecters?
Is there any in the wiring as the book says nothing??
If so what dose it light up when on low levels?
As there must be some warning light for SVA?
Thank for any info
Schrodinger
posted on 3/1/06 at 07:03 PM Reply With Quote
I assume it's the Tiger wiring loom?
All you do is take a wire from one of the side connectors on the master cylinder to earth and the other to the warning light on the dash to the same side as the hand brake warning light switch (if that makes sense) so that either the handbrake or the sensor turns on the warning light.
regards
Keith
Suffolk
mat.price
posted on 3/1/06 at 07:11 PM Reply With Quote
yes your right it's the avon wiring loom from tiger
is this what you have to do to all tiger looms even you cat??
DaveFJ
posted on 3/1/06 at 11:55 PM Reply With Quote
if you have the Tiger loom (same as the Cat loom - think they call it a 6 fuse loom?) then there is an excellent spreadsheet around somewhere that gives all the wiring colour codes... first thing i did was to sit down and label the entire loom... just to find that tiger sometimes change a couple of colours if they run-out!!!!
makes it easier to work out though
have a look here:
link
[Edited on 4/1/06 by DaveFJ]
Dave
Aboardman
posted on 4/1/06 at 01:05 AM Reply With Quote
"yes your right it's the avon wiring loom from tiger
is this what you have to do to all tiger looms even you cat??"
Even on a super 6 you have to do that, and do not foget the tell tale to the fog light.
i used a alarm led wired into the live feed out of the fog light switch, you could do as tiger say and wire the illuminated light back into switch, but this means the switch does not light up when you turn on the lights, i would prefer the seperate tell tale light.
ayoungman
posted on 4/1/06 at 09:06 AM Reply With Quote
tiger avon wires
from memory, there are two green wires on their own branch with spade connectors. To find them, locate the main branch that connect to steering column and go back down the loom. If you lay it onto the car in the approximate position, most things fall into place. I'll confirm tonite when I get home from work.
HTH
"just like that !"
Schrodinger
posted on 4/1/06 at 01:10 PM Reply With Quote
As has already been said yes I had to wire my Cat like that as they all have the same loom. While you're at it don't forget that the side repeaters for the indicators need to be "picked up" from the dash warning lights, I mounted my repeaters on the side of the scuttle rather than further down on the side of the car as Tiger suggest.
I hope this helps.
Keith
Suffolk
mat.price
posted on 5/1/06 at 04:50 PM Reply With Quote
thanks a lot this will all help
i will have a look this weekend and see how i get on?
tractorboy
posted on 9/1/06 at 07:08 PM Reply With Quote
hello mat if its of any help to you i have a built and sva'ed avon in burwell. i have it sorned at the moment but you are more than welcom to come round for a coffee and a nose about. scott
mat.price
posted on 10/1/06 at 08:43 AM Reply With Quote
hello scott
will be happy to pop over some time in the week if ok?
what best for you?
got a list of things to ask from wheel size to light wiring and more
thank matt
Rubix
posted on 23/1/06 at 01:28 PM Reply With Quote
There should be a push test button on the top of the brake master cylinder. You will need to connect the wires from this to your loom / low fluid indicator. SVA will push this button to test you have a low warning indicator and expect the light to glow. Thats wot they did on mine anyhow.
I have a Tiger Cat E1, and think the loom will b the same. If your not sorted yet let me know and I'll find out for u.
Never mind that s**t, here comes MONGO
