New Topic New Reply
Author: Subject: Made some progress....On a roll...
big_wasa
posted on 4/1/06 at 10:13 PM Reply With Quote
Well im determined to have the engine in and running and on its wheels by Easter.
So must crack on
Made the rack mounts, over did it a bit (all 3mm plate) It wont be going far!
Trial fitted the front wishbones, rack and uprights.
Cycled it all to check for bump-steer. Still a bit of tidying to do.
big_wasa
posted on 4/1/06 at 10:14 PM Reply With Quote
pic 2
Genesis
posted on 4/1/06 at 10:16 PM Reply With Quote
Looks good - reach around and pat yourself on the back... top job!!!
Going fishin'
Danozeman
posted on 4/1/06 at 10:20 PM Reply With Quote
Top job mate. The way your going it will be finished by easter,
Dan
Avoneer
posted on 4/1/06 at 10:39 PM Reply With Quote
Hi Big-W,
Hope you're gonna brace those top bone brackets, either with a horizontal bar between the two or with some plate.
P.S. Those ali clamps look really good
Pat...
big_wasa
posted on 4/1/06 at 10:49 PM Reply With Quote
Yep next job. It will depend on how I mount the shocks.
big_wasa
posted on 4/1/06 at 10:53 PM Reply With Quote
Yep mounts are good, dont spose you have the rubber bits learking in your garage Pat?
regards warren
RichardK
posted on 4/1/06 at 11:01 PM Reply With Quote
Looking great, hope mine turns out as well.
posted on 4/1/06 at 11:26 PM Reply With Quote
Get an old inner tube from your local tyre outlet and cut it into strips the right width then wind it round the rack till you have the right thickness and stick the clamps on over it.
Avoneer
posted on 4/1/06 at 11:47 PM Reply With Quote
Hi Big-W.
No, sorry mate, I never got any with them - didn't think you needed them either.
Racing bike inner tube is a good idea though.
Sorry,
Pat...
big_wasa
posted on 5/1/06 at 08:33 AM Reply With Quote
No probs Pat ........Still great mounts.
viatron
posted on 5/1/06 at 01:17 PM Reply With Quote
Arent those Rally Design clamps? Same as mine. To get the fit right i tried Rubber but they only need a very thin piece. ended up using Pop bottle plastic cut into a strip and wound round once. It wont compress like rubber and is weatherproof and doesnt degrade.
Mac
Alan B
posted on 5/1/06 at 01:19 PM Reply With Quote
I wouldn't worry about the 3mm for the rack mount....looks and seems about right to me..
big_wasa
posted on 7/1/06 at 11:00 PM Reply With Quote
Originally posted by Avoneer
Hi Big-W,
Pat...
So Pat do you think that will do it ?
regards warren
New Topic New Reply
