robertwa
posted on 5/1/06 at 05:59 AM |
Cutting aluminium sheet
What's best for cutting a straight line in 16 gauge diamond plate? Jigsaw, sawzall or angle grinder?
Rob
suparuss
posted on 5/1/06 at 06:15 AM |
best to use would be a circular saw with a proper blade, but a jig saw should be ok with a straight edge set. let the blade do the work and it
shouldnt veer off.
Russ.
steve_gus
posted on 5/1/06 at 08:36 AM |
dont understand what you mean by diamond plate, but I have cut 2mm thick alu with a hand nibbler. Using a hand grinders isnt a good method as alu is
soft and it tends to burr the edges quite badly.
I have also heard of a method where you 'score' the sheet with a sharp blade, then bend the plate back and forth on the axis to cause it
to break , but i havnt tried this method....
atb
steve
http://www.locostbuilder.co.uk
Just knock off the 's'!
jimgiblett
posted on 5/1/06 at 09:11 AM |
You shouldnt use a grinder on ali as it impregnates the abrasive. This can subsequently explode the disk with potentially injury.
Guillotine is best but then Circ saw or course bladed jigsaw. Note that the foot of the saw will mark the surface of the ali if not masked well.
posted on 5/1/06 at 09:33 AM |
Chequer plate.
Cut it with a jigsaw and use penetrating oil on the cut line. Gaffer tape on the base of the saw and cut from the rear and you won't mark the
surface.
ayoungman
posted on 5/1/06 at 10:20 AM |
I've done a lot of chequer plate on the landy. Definately go for jigsaw. Use a length of timber as a guide to achieve a straight edge.
Don't rush it ! HTH
"just like that !"
posted on 5/1/06 at 10:29 AM |
grinder - no; disc will clog as mentioned.
jigsaw is what I use but I tend to find the blade can wander off line so just keep an eye on it and adjust as required; usaully needs a bit of filing
to straingten up.
Sheers and cutters tens to distort the edge.
Another option is to use a hacksaw, the type with a free blade (don't know the exact name).
trextr7monkey
posted on 5/1/06 at 11:26 AM |
Industrial jigsaw with coarse blade and loads of oil on top of permanent pen marked line, have cut fairly complicated quarter inch tread plate using
this, oil makes job much easier but a bit smelly and ear muffs essential.
chrisf
posted on 5/1/06 at 02:34 PM |
I've found that a 1/8" cutoff wheel on an angle grinder works best. Then, clean up the endges using a file and long strokes. Jig saws are
very difficult to use IMHO.
--Chris
posted on 5/1/06 at 02:38 PM |
Jig saws may be difficult to use but they are safer . I knew a guy that nearly lost his arm due to incorrect use of a grinder when the disc exploded.
DO NOT USE ON ALUMINIUM!
chrisf
posted on 5/1/06 at 03:05 PM |
I'm no expert mind you, but I've been through 20 or so cutoff wheels and never once broken one. I use the ones with the fiber webbing and
never even had a crack. Still, if there is a big risk, I suggest others not follow my example.
--Chris
geoff shep
posted on 5/1/06 at 03:17 PM |
I've always had the best results on aluminium with a nibbler. Cuts straight, accurately and without any distortion (like you get with snips)
robertwa
posted on 5/1/06 at 03:24 PM |
Thanks guys,
I guess I will go buy a jigsaw so......
I had to leave all my power tools behind when I emigrated to US.
I'm sure I'll use it for other things anyway
Rob
James
posted on 6/1/06 at 03:15 PM |
I found the jigsaw even with ali blade to be utter rubbish!
So I very successfully used a 4.5" diameter 1mm angle grinder blade! Can't really see how there's enough mass for it to cut an arm
off- even at 9000RPM!
A fresh 9" diameter blade that's 3mm (1/8th) thick I guess might have enough mass to cause a problem but not sure I see it myself!
Obviously you must wear goggles, ear defenders and thick gloves.
James
[Edited on 6/1/06 by James]
- Muhammad Ali
posted on 6/1/06 at 03:22 PM |
Trouble I found when using a grinder was that the disc loaded up with aluminium so badly that it was barely able to work. I gave up when it started
to jam in the workpiece, and began kicking back...
Grinding discs work by wearing away the metal, whilst wearing itself away to expose fresh grinding edges - the ali stops that happening.
Jigsaw worked fine for me, as long as I took my time and allowed the blade to do its work without pushing.
lexi
posted on 6/1/06 at 06:17 PM |
Thing is guys it`s all down to the discs and blades that you use. I don`t recommend anybody does it but I have cut loads of steel with a Sthilsaw and
all types of angle grinders and have found that Stone type blades last longer and cut better than the metal ones. They do leave a burr on the metal as
they peel their way through it which has to be dressed.Have never found any grinders to be good on ally but Iaint found the right blade. Same with
jigsaws..crap. Until one day I found a few blades in my box which cut the ally really well so it`s a question of ringing the changes with blades and
cutting fluids.
Alex
planetester
posted on 8/1/06 at 11:12 PM |
Ive had real good finish with a b&q router, but you need a guide to follow otherwise you have no control at all.
