emsfactory
posted on 8/1/06 at 01:24 AM |
squealing alternator
OK. I have an awfull kia mentor. Long story but I have ended up with it.
Long list of MOT fails but most are done. I think its been in the sea.
Thing is the alternator squeals when its connected. I mean when the wires are connected not the belt. when I unplug the alternator there is no
noise.
Any ideas?
Also if anyone is looking for a shi...uperb kia mentor get in touch.
johnemms
posted on 8/1/06 at 01:39 AM |
silly question .. but have you tightend the belt up to see if it goes away? I mean unpluged means no load on the belt cause when it generates curent
it puts a load on the pully... no conection=no load=no squeal....
just my thought..
gazza285
posted on 8/1/06 at 01:46 AM |
Now there's a novel idea.
Genesis
posted on 8/1/06 at 02:06 AM |
Get a new belt - easiest way, you know it is! You'll end up doing that in the end, probably after the one that is squealing right now snaps and
leaves you in the lurch. It makes perfect sense whilst you'e working on the belt to renew it doesn't it?
Oh - did I say replace the belt?
Going fishin'
johnemms
posted on 8/1/06 at 02:20 AM |
has anyone looked at he time 2.30 in the dam morning.... mtv and kit cars!!!
gazza285
posted on 8/1/06 at 02:27 AM |
I know, I though about an early night around 10, what am I still doing up?
UncleFista
posted on 8/1/06 at 03:35 AM |
Squirt the belt with a bit of water from a spray bottle, if the squeak goes, it's the belt slipping.
Tony Bond / UncleFista
907
posted on 8/1/06 at 07:49 AM |
I might be wrong on this but doesn't running an alternator without it
being hooked up to a battery blow the diodes inside it?
I know next to nothing about electrics so I hope I'm wrong,
but for some reason I'm on my second alternator.
Paul G
Danozeman
posted on 8/1/06 at 09:45 AM |
It can do if run for ages like it.
Squirt the belt with WD40 or water. If it goes its the belt.
AS said above unpluging it will only remove the drag on the belt so even a slack belt wont squeal. The belts probably gone hard.
Dan
posted on 8/1/06 at 09:47 AM |
Under load it will squeal. Tighten the belt till there's absolutely no play in it anywhere then try it, not like the old dynamo.
theconrodkid
posted on 8/1/06 at 09:48 AM |
running an alternator un-plugged will kill it,
if the belt is ok and tight enough,check the charging rate,if the reg has gone and its charging flat out the belt wil slip,the battery boil,the
alternator explode and mankind shall cease to exist as we know it
who cares who wins
pass the pork pies
emsfactory
posted on 8/1/06 at 11:36 AM |
I have put in another alternator and the squeal is still there, its had a new belt has been degreased, along with the pulley and has been tightend up
and it still squeals?
I'm stuck.
If the car would explode when running with with the alternator unplugged maybe I'll just do that.
Could be fun.
MkIndy7
posted on 8/1/06 at 12:25 PM |
Might sound daft but is it the water pump bearings or any other pulleys that the belt comes into contact with, and just happens to sound like its the
alternator?
emsfactory
posted on 8/1/06 at 01:43 PM |
The water pump was changed yes. Would that be right that when the alternator is connected the water pump could cause the squeal?
posted on 9/1/06 at 11:22 AM |
alternator?
This is sounding like a pig to find!!!
no daft, but logical conclusion. Get a mechanics stethoscope or a long cardboard tube placed to ear to identify source of squealing.
Unless you have 2 bad alternators, I would guess the source is elsewhere.
