Dillinger1977
posted on 8/1/06 at 10:22 PM |
vortx dash test
hello chaps,
just fiddling with photoshop to try out a dash idea I had. i want to use that sheet carbon effect plastic stuff to make a dashboard shape. mainly to
calm the WALL OF ORANGE COLOUR down a bit.
is this sort of thing doable for SVA, or will i need to round the edges of it off a bit? (its 2mm deep afaik)
standard r1 00/01 clocks, 2 fan/fog switches and a brake light. minimalist, but i like it that way. (might be tempted for a fuel guage later
though!!)
what do you think? (the steering wheel will obviously be changed post-sva!)
![](/galpreviews/rogdashtest.jpg) ![Description](/gallery/rogdashtest.jpg) Description
cheers!
-Rog
tom court
posted on 8/1/06 at 10:34 PM |
dash
looks very cool
is it the plastic effect carbon, how did u cut it ?
RichieC
posted on 8/1/06 at 10:45 PM |
Looks good to me mate, tempting me back away from using a digidash cos I really like the R1 clocks.
As for the SVA question, I honestly couldnt say whether theyd count that as a projection and therefore be subject to the radius issue. If its not too
hard to radius, Id do it just to be sure, otherwise ask them directly.
Rgds
Rich
donut
posted on 8/1/06 at 10:47 PM |
Crumbs! very nice!!!!
muzchap
posted on 8/1/06 at 11:19 PM |
Looks awesome! :-)
Are you fitting any other dials?
Perhaps you could get TRITON to mould that whole segment for you - so the clocks sit inside a nicely radiused housing - with the carbon trim of course
If quite a few people are planning the same - you might be able to do a deal?
It'll look very professional then - which i'm sure the SVA Man will appreciate :-)
smart51
posted on 9/1/06 at 08:15 AM |
Carbon effect plastic is just plastic with a stick carbon effect film stuck to it. Why not just use the carbon effect film? It is about 0.05mm thick
and so can be cut with a sharp knife and will stick to the vortx dash without having a raised edge. Its also stretchy and so can be wrapped around
the return edges around the steering column. You can also wrap it around the curved lower edge. Much neater.
I got some off eBay but companies that do car panel wraps should be able to supply it. They may even be abe to laser cut it if you can supply a CAD
template.
Dillinger1977
posted on 9/1/06 at 08:25 AM |
that might be a better idea colin, in which case i could be tempted to do the whole lower part of the scuttle (like the orange MNR car with inlaid CF)
which looks great!
i'll have a look about for some film
-Rog
viatron
posted on 9/1/06 at 09:10 AM |
Dont tnink SVA will be a problem at that thickness, bouight a couple of sheets of this myself and the chap i bought it off said a router was the best
way to get a good edge when trimming / cutting it.
Mac
NB: iof you do use a router then you could use a quarter round bit to radius it anyway.
Agriv8
posted on 9/1/06 at 09:22 AM |
HI Rog,
I am sure someone will correct me if I am wrong - but anything that is within the steering wheel radius plus 172mm ( please check before commiting )
is ok to be non radiused .
May be worth looking at the radius of the clocks before as well. All the gauges ont' V8 are withing this measurement. as the beveles are border
line !.
A length ou U trim rubber arroung the Carbon affect plastic, is another option for SVA. I have donne this arround the exhaust exit pltes on the side
of mine ( more a case of hiding dodgy cutting than SVA )
Dillinger1977
posted on 9/1/06 at 09:32 AM |
heh heh!
the clocks -should- fall within the steering wheel radius (with gigantic sierra wheel fitted) but i was unsure of the carbon stuff just going past the
radius.
the U trim is an option that could work well.
thinking about it, the stone chip guards on the rear wheel arches are the same material. do these need U trim for sva, or is that area exempt from
the testing?
-Rog
Agriv8
posted on 9/1/06 at 09:52 AM |
Rog - would leave the rear protector's off until after SVA as I am unsure about the radius unless you are already commited of course !!
Dillinger1977
posted on 9/1/06 at 10:05 AM |
not yet...
good thing im so blummin slow isnt it?
-Rog
amalyos
posted on 9/1/06 at 11:13 AM |
The dash looks great, I may pinch the idea if thats ok, as mine will be a bit bright as well!!
![](/images//smilies/wink.gif)
G.Man
posted on 9/1/06 at 12:08 PM |
Looks great Roger...
Opinions are like backsides..
Winston Todge
posted on 9/1/06 at 12:19 PM |
What have you got left to do now then mate?
Dash looks wicked.
Take it easy,
Chris.
Dillinger1977
posted on 9/1/06 at 01:29 PM |
cheers chaps!
i still havent 'done' the dash yet, as i said its just a photo manipulation job to see what it would look like but i think that it'd
be a good way to do it.
whats left? ooh. lots. ive done next to nothing since the last time i posted as ive got loads of 'other' work on at the moment.
its mainly wiring and cables before i get the engine fired up, and some 'finishing' stuff like boot panels + dash.
i was terrified of the wiring but ive just got a bit casual about the whole thing now and am going to have a go whether i make an arse of it or not.
-Rog
JoaoCaldeira
posted on 9/1/06 at 01:40 PM |
Here's a great idea... Mine will be orange, too, so beyond sun glasses, this could be the best bet...
Joao
