richyo
posted on 20/1/06 at 01:50 PM |
Side Light Wires
Got my near & off sides confused when wiring my headlights, so the cable for nearside is now at off side and cut to suit and vice-versa.
Does it make any difference ? I can't see why not but some of you I'm sure can advise.
TIA
Richyo
Howlor
posted on 20/1/06 at 02:27 PM |
I would have thought it was fine. Generally side lights are on a single fuse anyway so it doesn't matter.
posted on 20/1/06 at 02:32 PM |
no, but may help trouble shooting in the future.
can;t you just swap over the connectors for the two lamps or is it a trick question?
stevebubs
posted on 20/1/06 at 02:33 PM |
so long as there's no difference in the lens / beam pattern then you should be fine
Stephen
shortie
posted on 20/1/06 at 02:50 PM |
but aren't they fed by the same wire (and therefore same colour wire) anyway so it makes no difference, or am I missing something here!!
richyo
posted on 20/1/06 at 03:14 PM |
Thanks gents
Its a PW loom and there are different coloured wires for O/S & N/S so I thought there was a reason.
DarrenW
posted on 20/1/06 at 03:27 PM |
all i would do is leave wires as they are and make a note on the PW instruction sheet for future reference.
