New Topic New Reply
Author: Subject: chrome
Craig81
posted on 22/1/06 at 07:42 PM Reply With Quote
chrome
Hi all,
can anybody give me an idea as to how much it cost to get my wish bones chrome plated.
cheers
craig
k33ts
posted on 22/1/06 at 07:51 PM Reply With Quote
last chroming i had done was on a kx250 supermoto complete exhaust £35
if that gives you some idea of cost
posted on 22/1/06 at 08:25 PM Reply With Quote
Chrome costs are about to go through the roof new EU environmental protection laws will close a lot of small outfits.
istr advice from MSA sources is against chrome plating suspension parts anyway -- because it hides cracks.
Nickle plating or cadmium dip is OK.
[Edited on 22/1/06 by britishtrident]
posted on 22/1/06 at 08:36 PM Reply With Quote
I seem to recall reading somewhere that the chroming process, involving dipping in acid, would weaken the metal so not a good idea I would have thought?
Johnmor
posted on 22/1/06 at 08:52 PM Reply With Quote
Chrome
If you are going to get things chrome plated make sure that any cleaning agent can flow out freely from the object , as was mentioned, acid is used and if it remains in the wishbone after cleaning then it will corrode from the inside out.
Happened to a friend of mine ,had a lovely Norton frame that you could crush with your fingers about four months after it had been chromed.
Acid got trapped in the frame.
posted on 22/1/06 at 10:07 PM Reply With Quote
One potential problem with chrome plating plating is hydrogen embrittlement, which is the last thing you want on a heavily loaded bottom wishbone. This isn't a problem if the people doing the chroming apply the correct heat treatment after the chroming process.
pifular
posted on 22/1/06 at 11:27 PM Reply With Quote
cost me £20 to get my mk bones powder coating cleaned off and then £60 to get them chromed and polished at aback street place in manchester. was very good and can reccommend.
prices are for the pair btw.
most difficult part was finding a bolt with the right thread to fit into end of top wishbone to protect internal threads.
they do also have small holes in them now to drain all fluids used out as mentioned earlier in another post.
New Topic New Reply
