Danozeman
posted on 17/2/06 at 06:20 PM |
Zetec gearbox plate.
Is the plate needed between the gearbox and engine?
If so has anyone got a template for zetec to type 9? Longshot i know.
[Edited on 17/2/06 by Danozeman]
Dan
auzziejim
posted on 17/2/06 at 06:31 PM |
standard ford bellhousing pattern so the type 9 will bolt straight up so would a 4 speed if desired
Danozeman
posted on 17/2/06 at 06:39 PM |
Sorry wasnt that clear. Theres that tin plate that goes between to cover the open gaps.
Dan
posted on 17/2/06 at 06:43 PM |
Yes it is needed it helps locate he starter.
CVH Sierra one "should" fit with minor adjustments ---- Pinto Sierra one needs big lumps cut out.
auzziejim
posted on 17/2/06 at 06:44 PM |
ah that old thing! i may have one kicking about somewhere to be honest i dont think i bothered with one on my mk2 escort
will look tomorrow see if i have one
BKLOCO
posted on 17/2/06 at 06:45 PM |
In a word Yes you do need the plate.
I used a standard pinto one and attacked it with a nibbler until it fitted.
APR
posted on 17/2/06 at 06:51 PM |
no never used on on my 1.8 silver top zetec and have not used one on my 2.0 black top. everything seems fine.
stevebubs
posted on 17/2/06 at 06:54 PM |
Yep - Sierra 1.8 CVH attacked round the middle area with an angry grinder does the trick quite nicely...
big_wasa
posted on 17/2/06 at 08:28 PM |
Make one
ecosse
posted on 17/2/06 at 10:05 PM |
That looks kinda familiar warren?
Alex
Danozeman
posted on 18/2/06 at 09:45 AM |
Im too lazy to make one. Whats the likely hood of a breakers having on of them..
Dan
auzziejim
posted on 18/2/06 at 04:07 PM |
i have a pinto one if it helps surples to reqs
big_wasa
posted on 18/2/06 at 10:53 PM |
Alex
I made two
