auzziejim
posted on 19/2/06 at 08:54 PM |
is it possible?
to run a pinto on bike carbs using the dizzy? iv heard of it being done but am a little dubious
UncleFista
posted on 19/2/06 at 08:56 PM |
Dunno why not, is the dizzy gonna get in the way of a set of carbs ?
Tony Bond / UncleFista
omega0684
posted on 19/2/06 at 08:58 PM |
what is a dizzy?
rayward
posted on 19/2/06 at 09:01 PM |
shouldn't be a problem, obviousely you'll need a dizzy cap with right angled connections, also some bike carbs are designed to be fitted
at an angle(the air filter fits in a recess inthe fuel tank), using these should give you a bit of extra clearance.
Ray
jeeby_man
dizzy = distributor
big_wasa
posted on 19/2/06 at 09:06 PM |
I think you mean the problems due to lack of a constant vacume to run the advance/retard mech.
Run a line to each runner feed them all in to a small chamber to act as a damper then feed the dizzy from that.
auzziejim
posted on 19/2/06 at 09:10 PM |
wouldnt vacumless distributor sort that problem? i was thinking of the fuelling would i need some sort of ecu to control it?
907
posted on 19/2/06 at 09:28 PM |
That's a cracking idea Wasa.
I'm running twin Delortos and I also have a vacuum gauge. The gauge was into no4
and the advance pipe into no1, but the gauge flickered so I joined 1 to4 and joined
into that. It still flickers a bit.
Your idea of joining all four with a damper chamber would be better for the gauge
reading and a more stable feed for the vacuum advance. I'll try that.
Cheers.
Paul G
jacko
posted on 19/2/06 at 09:35 PM |
Hi just fit them and go . Its better to have megajolt but it can be done with original dizzy . have a look in my photo archives under zx9r
Jacko
big_wasa
posted on 19/2/06 at 09:38 PM |
I nicked the idea from Paulf he used a small spent co2 bulb.
jacko
posted on 20/2/06 at 08:25 PM |
HI Big Wasa what is a co2 bulb please
Jacko
big_wasa
posted on 21/2/06 at 08:13 AM |
l
ink
posted on 21/2/06 at 11:54 AM |
Why do you need vacuum with dellortos?
My understanding is it is there to improve ecomomy/emission at low loads
Although I have vacuum line fitted to front carb and advance unit, I will see how my engine runs without vacuum advance. If I can find the vacuum
take off on the other carb, I'll try the vacuum chamber idea to see if it is any better.
posted on 21/2/06 at 12:08 PM |
with a vac gauge you need a restricter followed by a volume --- for the volume try the fuel trap between the throttlerbody and the ECU from a 90s
Rover. For the restricter just make an adjustable clamp for the rubber hose.
posted on 21/2/06 at 12:10 PM |
quote: Originally posted by omega0684
what is a dizzy?
In my neck of the woods it is when your date stands you up. --- ;-)
paulf
posted on 21/2/06 at 12:41 PM |
Or put a .6mm mig nozzle in the line , I found one is a push fit into the 4mm vac tubing I am using . I used a cut down Co2 bulb as a fuel trap and
soldered a top on it with an inlet and out let pipe made from brake pipe as i couldnt find a suitable fuel trap .It is a good idea to have a fuel trap
in line anyway as i found my map sensor had got fuel in it after a few miles with out a trap fitted.
Paul.
paulf
posted on 21/2/06 at 12:45 PM |
I have a few spare if anyone wants one ,as i have a co2 powered air pistol that uses the bulbs and they are disposable when empty.Willpost a picture
later of how mine is fitted.
Paul.
Jacko
