Author: Subject: What weight is a Sierra shell?
brashhighlander
posted on 22/2/06 at 04:18 PM Reply With Quote
Hi
Does anyone know the answer to the question above. I am about to dispose of my donor and I have managed to get my hands on a small trolley which can cope with 200kg. Will this be enough to move a bare sierra shell.
Jim
flak monkey
posted on 22/2/06 at 04:21 PM Reply With Quote
At a guess no i would put the bare shell at more like 300kg (guesstimate)... But you might be ok. Depends just how bare it is...
I have heard of people moving a bare shell on 4 roller skates though, so it cant weigh too much...
Sera
http://www.motosera.com
oliwb
posted on 22/2/06 at 04:22 PM Reply With Quote
Dunno if your planning to keep the trolley or not but if your not worried about it breaking I would go for it anyway....imagine they must build in a bit of lee-way for them! Good luck....Cheers Oli.
brashhighlander
posted on 22/2/06 at 04:40 PM Reply With Quote
Problem is its not mine. Borrowed from a mate who uses it to move furniture, so I don't want to break it.
Oh well, only one way to find out.
posted on 22/2/06 at 04:49 PM Reply With Quote
I rolled mine out to the Hiab on two bread tray trolleys "borrowed" from the local kwik e mart, one of them is now propping my chassis up and makes a good turntable.
Locost?
posted on 22/2/06 at 05:06 PM Reply With Quote
It all depends on what surface you are moving it on. Me and a mate manhandled my Capri shell on to the back of a farm trailer. It was bloody heavy, I would guess at least 150kg and thats with everything removed, doors, bonnet and tailgate included. The other option is to get the big grinder on it, few hours should give you more manageable pieces.
7 in a fancy suit
posted on 22/2/06 at 05:28 PM Reply With Quote
About 20 minutes with a 9" grinder and a BFH will lop off the roof at the base of each pillar and a cut across the floor in either the front or rear door area gives you nice manageable pieces. I'm presuming you've taken the doors, bonnet and boot off as well.....if not.....another 5 minutes with the grinder. Many cars have left my driveway in this state.
A man gets lonely in the desert.......and bored
emsfactory
posted on 22/2/06 at 05:31 PM Reply With Quote
Weight has nout to do with surface. I weigh the same on grass as I do on concrete.
oliwb
posted on 22/2/06 at 05:59 PM Reply With Quote
Know anyone with a four wheel drive either with a winch or not....they could just haul it out for you??? Oli.
Mark Allanson
posted on 22/2/06 at 07:30 PM Reply With Quote
A large wood axe is even quicker, you can literally halve a sierra in about 5 minutes
Danozeman
posted on 22/2/06 at 08:57 PM Reply With Quote
Could u not weld some cheap Bnq casters on the bottom?
Cut it up and have some fun
Dan
NS Dev
posted on 23/2/06 at 11:53 PM Reply With Quote
These are really good.
I have a heavy duty supermarket "cage trolley" (breadcrate trolley thingy) which I have widened and use as a bodyshell buggy, and used it to move my lathe, which is well over 1/3 tonne, so no worries there!
brashhighlander
posted on 24/2/06 at 09:33 AM Reply With Quote
Well I managed to move the shell without any problems. I used the skate at the back and a trolley jack at the front, so it didn't weigh as much as I thought.
It was quite funny seeing some of the neighbours looking out their windows at this cut up and bashed shell at the side of the road.
Now its time to start cleaning all the donor parts and zetec engine.
Jim
