scutter
posted on 25/2/06 at 06:54 PM |
Broken wing stays
Well I've offically joined the club, broke the wing stay today (indicated in red) and like others I'm looking for a way to improve the
design?
I think to first error was using 3.2mm flat strip for the piece over the wheel and secondly having to run them 55mm off the upright to clear the focus
wheels offset.
Do you think I could get away with replacing the strip with a 6mm piece or will this move problems elsewhere?
Also will a piece of the same size flat strip assist the stability(drawn in blue)
Many thanks Dan.
[img][/img]
raccoonradar
posted on 25/2/06 at 07:20 PM |
after breaking 3 in 2days i removed mine & bent a same bit of metal and welded under the original length, now they don't even move, before
they would wobble every Bump or bit of gravel![](/images//smilies/bigsmile.gif)
posted on 25/2/06 at 07:55 PM |
id skip the blue idea myself. It breaks at the red line usually (mine did) due to the change in section (stress point) and the edge of the heat
affected zone around the weld. Only idea that occur to me (not tried them as i never bothered fixing mine!) is weld a small arc shaped piece of metal
over the join, at 90 degrees to the flat piece. This reinforces the weak point, and spreads out the stress point.
Ideally the flat piece would be blended with the round tube smoother, maybe notched together or somesuch.
Avoneer
posted on 25/2/06 at 08:10 PM |
Mine never broke.
I just used 2 lengths of flat right from the mounting plate.
Nothing to snap.
Pat...
Avoneer
posted on 25/2/06 at 08:12 PM |
Pic...
posted on 25/2/06 at 09:04 PM |
Mine broke in about 500 miles, welded break and reinforced with another length of 3mm steel. So far they have been OK .
Alan_Thomas
posted on 25/2/06 at 11:16 PM |
An addition like that in blue would not help. They fail (mine did!) through fatigue of the guards jumping up and down.
I doubled up the 3mm flat strip from the end of the rod round the curve and half way across the guard.
Welded down each edge, dressed it with a gringer/file and it looks like 6mm strip with fully rounded edges.
Not broken since and the guard does not bounce either.
Remember it not the weld that breaks (well it shouldn't if the weld was good, its the stress concentration at the point where the bendy strip
meets the rigid rod.
- Alan
