Chris_G
posted on 28/2/06 at 03:11 PM |
Zetec coolant temp sensor connector.
As per title. Anyone got a spare connector to suit the sensor type shown below?
Chris
![](/galpreviews/a332089-94_1_b.JPG) ![Rescued attachment 94_1_b.JPG](/gallery/a332089-94_1_b.JPG) Rescued attachment 94_1_b.JPG
Now finished! Xflow-Zetec swap with GSXR TB's and Megasquirt.
Aboardman
posted on 28/2/06 at 05:49 PM |
cannot see the pins but does it not take the small electrical connections.
on my zetec i had to connect 1 pin to the temp sensor, the other pin to earth.
Chris_G
posted on 28/2/06 at 05:56 PM |
Yes, it has got 2 round pins which I could probably use bullet connectors for, but it would be much nicer to have the proper connector
Chris
BKLOCO
posted on 28/2/06 at 06:44 PM |
I think I've got one.
There were 2 types used though so will need a picture looking down at the pins so as to orientate the 90 deg angle on the plastic bit in relation to
the pins as this is what was different.
If it's the right one I'll pop it in the post.
Chris_G
posted on 28/2/06 at 07:39 PM |
Thanks BKLOCO!
I'll take a picture tonight and post it later. The picture above is one I found on eBay so it's not even the one to be used anyway but I
didn't know there was more than one.
Thank again,
Chris
Dusty
posted on 28/2/06 at 08:57 PM |
Is that the sensor for the ECU or the temperature guage?
Nigel
Chris_G
posted on 28/2/06 at 10:35 PM |
BKLOCO, here's a picture........
If it matches up, let me know and I'll drop you an email or U2U
Dusty, this is the standard Ford coolant temp sensor that will be used as the Megasquirt input. There will be a seperate VDO sensor for the guage
(Don't supose anyone's got one of those before I go and buy one?)
Chris
![](/galpreviews/a332411-temp sensor.jpg) ![Rescued attachment temp sensor.jpg](/gallery/a332411-temp sensor.jpg) Rescued attachment temp sensor.jpg
BKLOCO
posted on 28/2/06 at 10:43 PM |
Yep. Got a choice of 2 of those.
Black one or a white one.
U2U me an address and I'll pop it in the post.
Dusty
posted on 1/3/06 at 01:27 PM |
Thanks Chris.
