locost7-online.com
posted on 5/3/06 at 08:47 AM |
Which Bike engine?
Im thinking of an upgrade to bike engine, currently a 150bhp injected crossflow which is quick, i just fancy a change what are the reccomendations?
POWER, RELIABILITY, COST, EASE TO FIT.
Locost Xflow 150bhp injected! Sold :-(
Facebook blog https://www.facebook.com/Johns-Tiger-Avon-Build-814223212056368/
PLEASE NOTE THIS MEMBER IS NOT A TRADER.
Gav
posted on 5/3/06 at 09:25 AM |
The usual suspects:
R1
Fireblade
ZX-9R
ZX-10R
ZX-12R
'Busa
GSXR-1000
Most people seem to use the R1, personally ive got a '97 Fireblade engine, i dont think youd have many problems with any of them, of course they
prices will range from 400ish for a zx9r to 3k for a Busa!
cossey
posted on 5/3/06 at 09:32 AM |
the fireblade has less power than the crossflow (135bhp) but is cheap fairly reliable
the r1 is becoming fairly cheap (1000ish) for the older engines (upto 01 for carbs and 03 for fuel injection) they have around 155 bhp, and are
pretty much bulletproof. the newer (04+) engine are much more powerfull (175-180) but the price reflects this (1500-1900)
the gsxr is a bit more powerfull than the r1 but is expensive (£1700+) and requires dry sumoing which adds about a £1000. its abit unknown and not
popular.
zx 9r: half way between a fireblade and a r1/gsxr
zx12r cheap powerfull may require dry sumping? a good busa alternative about 175bhp
hayabusa very expensive but amazing tuning potential. costs about £3000 plus another £1000 for dry sump, produces about 180bhp but can be tuned
without turbo to 250ish bhp and with to 400ish bhp reliably.
zx14r not out yet but this might take over from the busa as it has more power (200bhp) and also might lower busa prices.
if you want something cheap and reliable go for the r1 (that was what i was told by Martin Bell at the kcw for my fury and they have made a very large
number of becs.
id recommend yorkshire engines (hes on here) for good deals and excellent service for whatever you choose
posted on 5/3/06 at 09:39 AM |
Depends how much cash you want to spend and what sort of power you're after. Most of the big bike engines are about 125bhp upwards. For a
1,000cc engine (or thereabouts) you're looking at, in no particular order, ZX9R, CBR1000, R1, Fireblade, GSXR etc. Although a lot of people are
currently going for the R1 engine and more recently the newer GSXRs, I reckon the Blade has still got to be the easiest install, although none are
particularly difficult and the R1 has excellent power to weight.
Then there's the bigger bike engines; the Blackbird, Hayabusa, ZX12R etc, which produce around 170bhp but some will say require dry sumping.
The Blackbird would need some additional protection in the form of a dry sump or at least an Accusump, if intended for track use. Others will argue
that the Hayabusa and ZX12R also require dry sumping but there's other threads discussing these issues if you do some searching.
Most of the bike engines are reliable. Cost wise, there are bargains out there to be had and you might be able to pick a full engine up for around the
£500 mark but as these are few and far between, realistically you'd be looking at £850 to £1,500 for the smaller engines, a bit more for the
ZX12R and then a fairly big jump into Hayabusa territory.
All bike engines are quite easy to fit but will obviously require a few modifications to your existing chassis and replacement of a few bodywork
parts.
edit: Must learn to type quicker
[Edited on 5-3-06 by Hellfire]
G.Man
posted on 5/3/06 at 09:45 AM |
without turbo to 250ish bhp and with, to 400ish bhp reliably.
Worth pointing out that BHP wise the ZX12R is higher than the Busa, but the Busa has slightly higher torque...
The ZX12R can also hit 250bhp with no issues normally aspirated...
Our race R1 is putting out 190bhp at the rear wheel, so they can be tuned to give big bhp as well...
Dry sumping is also not just about oil pressure, it gives an increase in power as well... less oil drag on the rotating parts..
R1 with carbs is by far the best overall package for simplicity and performance... Once you go fuel injection, the messing about increases markedly to
get it all in and running right...
[Edited on 5/3/06 by G.Man]
Opinions are like backsides..
dern
posted on 5/3/06 at 09:48 AM |
One reason I went for the R1 engine is that the output shaft is nearer the block if you see what I mean which means you can have more space for your
feet on the drivers side.
Regards,
Mark
R1 (2003 FI) powered Locost in progress
Fireblade/Impreza
the_fbi
posted on 5/3/06 at 11:07 AM |
The 954's (RR-2/3) are 149bhp as standard, 929 is 135bhp
RR-4/5 (998cc) are 178bhp so very nice
You can also pick up Yoshi EMS for the injected blades for much less than a Powercommander, giving full fuel/ignition mapping.
uklee70
posted on 5/3/06 at 11:16 AM |
Just thought I would add the Tirumph to the listing
Daytona 150bhp I picked up an 03 engine for £550 and with tuneboy software you can map the ecu
Down side is they are not proven in locosts. but cheap hp
Lee
posted on 5/3/06 at 11:19 AM |
IIRC the Yoshimura EMS is/was a re-branded Power Commander with a few additional features and were quite temperamental.
stevec
posted on 5/3/06 at 11:32 AM |
Be aware that post 95 engine may need a Cat for SVA.
ChrisGamlin
posted on 5/3/06 at 11:38 AM |
The thing is, although the blade has less power than the current xflow, it will still be quicker. From on following other cars on track I'd say
you need at least 170-180bhp from a car engine'd car to give equivalent straight line performance, partially due to the weight and partially due
to the gearbox.
Saying that though, having done the blade to R1 conversion the R1 is a useful boost in performance so unless you're on a really tight budget I
would go for the Yam engine. Also don't be too scared of the 02/03 injected engines, there's a few more wires to work out what does what
but Im certainly no wiring guru and I didnt find it any more taxing than the blade.
Chris
ChrisGamlin
posted on 5/3/06 at 11:39 AM |
Steve, no SVA needed if he's converting his current car thats already road registered.
the_fbi
posted on 5/3/06 at 12:20 PM |
Hm...
I really don't think this is the case, or that it could have been.
http://www.yoshimura-rd.com/ems.asp
The Power Commander may be a cheap knock off of the Yoshi though.
posted on 5/3/06 at 01:32 PM |
I seem to recall reading somewhere that Dynojet designed the original EMS for Yoshimura and would possibly explain why the maps are
interchangeable.
Suppose it could have been the other way round as well though but who cares?
Phil
stevec
posted on 5/3/06 at 02:15 PM |
Chris, Ooooops having another thick moment there I must learn to read.
Steve.
[Edited on 5/3/06 by stevec]
alister667
posted on 5/3/06 at 03:08 PM |
Just a word on the GSXR-1000, a mate fitted one into an MK de-dion chassis and drove it round France last summer (about 2000 miles I think). He was
happy with the performance, he kept the orginal sump - uncut, even though it's a tall engine - and no problems, although that's not tried
on track.
The one problem he said he had was the close gearing - first was too tall and 6th too short - by the time he had a diff and wheel size to give him a
decent cruising he found that his first was more like 2nd on a blade, making stalling even easier. Unless you lit her up of course
He's currently considering going with a modern car engine (zetec pehaps) for this, his 'touring' car.
http://members.lycos.co.uk/alister667/
cossey
posted on 5/3/06 at 04:43 PM |
the tall first closer gearing thing is common to all the new litre bikes. my r1 will when finished do over 75mph in first and 150mph in 6th whereas a
car of similar top speed would do more like 45mph in first.
my aim when ive finished mine is for 500bhp/tonne with fluids plus half a tank of fuel and it should be possible to get my r1 to 213bhp n/a and get
the weight to 425kg or atleast a good challenge.
tomblyth
posted on 5/3/06 at 04:58 PM |
engine
saw this on e-bay
brand new yamaha R1 engine with carbs
Item number: 8042392286
http://cgi.ebay.co.uk/brand-new-yamaha-R1-engine-with-carbs_W0QQitemZ8042392286QQcategoryZ25640QQrdZ1QQcmdZViewItem
ChrisGamlin
posted on 5/3/06 at 07:33 PM |
cossey, out of interest how come you are gearing it so high? Its going to be a right PITA to pull away with such a high first gear, and although with
the enclosed Fury bodywork you've got a fair chance of reaching well past 140mph, I can't think of any UK circuit where you'll be
able to get anywhere near 140-150mph.
Also, what gets done to an R1 engine to get it to 213bhp N/A, sounds like a very expensive engine to me?
G.Man
posted on 5/3/06 at 10:10 PM |
LOL be prepared to spend a poo load of cash then....
To get that BHP out of an R1 you are gonna need it...
It can be done, but its VERY expensive... as we have found out with our superbikes, and you will need standalone engine management...
cossey
posted on 5/3/06 at 10:26 PM |
gearing is to get a half decent cruising speed in top. by doing this 70mph gets to a more reasonable 6750rpm, also those speeds are at 14,000rpm so in
reality the gearing isnt as high as it seems.
the engine is a 2006 so 175bhp as stock (although in reality it is a couple more) to that you need to add a decent exhaust, new inlet trumpets (the
stock ones are too short), a thinner head gasket to raise the compression (yamaha racing part) and the head gets tidied up ( the domes a polished to
reduce detonation, the inlet and exhaust runners are cleaned up to remove the casting marks, the valve seats hould be ok as they are 3 angle as
stock)
all of that should net 200-205 bhp when properly mapped ( i have seen dyno plots from several people with similar specs on different dynos so im
fairly confident the figures add up) also this will boost low down 2 with a bit of length tuning on the inlet and exhaust to improve the 6000-8000 dip
the stock engine has. the dip is mostly due to the exup valve and the lower half of the fuel map being lean to pass emissions regs.
the last 10-15bhp will be a second stage after the car has been through sva and the engine has run in a bit (the engine came out of a less than 2 week
old bike that had done under 100 miles), but itll probabily involve boring out to 1050cc with high compression pistons, new rods and cams. i might get
away with just cams and rods with the stock bore and pistons but i havent had a chance to have a good look at them yet.
G.Man
posted on 5/3/06 at 10:38 PM |
Ah, the mythical dyno plots... well they must be accurate right...
I have seen 2005/6 r1's with stock dyno readouts (on the same dyno) varying between 150 and 170bhp so you better hope your 100 miler is a
goodun, otherwise you are gonna need a lot more mods than that, I have yet to see a stock R1 giving 175 at the crank (calculated) and thats on a newly
calibrated dyno... not one thats used down your local dyno shop that hasnt seen a service for the last 5 years...
I have seen some putting out more than 180 on old junker dyno's tho...
cossey
posted on 6/3/06 at 09:40 AM |
i dont believe evervy dyno is right but i do believe that taking averages over enough plots and discarding any results that are too far from the norm
in either direction should be reasonably accurate.
most dyno results show the stock bike putting down 150-155rwhp which is somewhere arond 170-175 at the crank.
if it doesnt make the power then i will try to cut the weight some more but im sure its possible to get it to atleast 210bhp.
GEORGE80
posted on 6/3/06 at 07:49 PM |
fazer 1000 is a good all rounder, quicker in a bec than the r1 and blade as it has a reworked head giving it a lower power band and more tourque from
lower down and is around a grand to buy
G.Man
posted on 6/3/06 at 10:05 PM |
I have no doubt you will get the power, we have achieved over that figure on our race R1's... Its just very expensive
