Author: Subject: polybushes
jay taylor
posted on 5/3/06 at 08:07 PM Reply With Quote
polybushes
just a quick one lads. The inner sleeve of the polybush should the ends sit flush in the bush????
Thanks in advance
Jay
SeaBass
posted on 5/3/06 at 08:09 PM Reply With Quote
I've just cracked a beer and i'm in for the long haul...
rayward
posted on 5/3/06 at 08:10 PM Reply With Quote
mine stick out a couple of mm,when they where flush, the sides of the bracket 'nipped' the bushes and made them tight.
(stands back and waits to be shot down!)
Ray
[Edited on 5/3/06 by rayward]
posted on 5/3/06 at 08:17 PM Reply With Quote
i think everyone agrees that polybushes are not meant to deform, the crush tube should be gripped tight and the bush pivots on it.
Where the disagreements arose, was what length crush tube was best. I believe it depends on the shore rating of the bush. Some argued that the crush tube should be fractionally longer, to leave the bush completely free. Some said it should be the same length, and the bush lightly pinched but still free to move (to prevent slop, apparently) and still others argued that even if the crush tube was ever so slightly shorter, it could be gripped up tight anyway and the bush itself would be a little more squeezed.
My own take, its all nonsense Pick your favourite reasoning and do it that way, the car wont fall apart cos of it.
Its alright mark, the old arguments were between syd, rorty and doz, theres only syd left now so an arguement is less likely!
[Edited on 5/3/06 by JoelP]
jay taylor
posted on 5/3/06 at 08:23 PM Reply With Quote
from the replies a few of you have sent it looks like i may have opened a can of worms just thought i should ask cuz its better safe than sorry cheers for the help
Avoneer
posted on 5/3/06 at 08:25 PM Reply With Quote
Originally posted by chris mason
right then better sit down and get comfy this could be a long one
Chris
mark chandler
posted on 5/3/06 at 08:32 PM Reply With Quote
If you buy a set of polybushes for a landrover the bush sits flush with the tube.
Polybushes are generally much harder in use than rubber so you should not need to squeeze them or you may just end up overloading the mounts by restricting the flex even more.
On a landrover a polybush also pivots on the cush tube, you even get molyslip grease to ensure this happens. The standard rubber item is a sleeved bonded bush so you effectively twist the rubber so only tighten when the suspension has settled.
If thats any help !
Regards Mark
big_wasa
posted on 5/3/06 at 08:33 PM Reply With Quote
can of worms or not tell all as they are soon on the list to make buy.
daviep
posted on 5/3/06 at 08:42 PM Reply With Quote
In the real world the tube should be as short as possible while still leaving the bush free to pivot, as is my understanding. If the tube is too short and the bush is tight there is a very real risk you'll rip the bracket off the chassis.
Confused but excited.
posted on 5/3/06 at 08:43 PM Reply With Quote
I realise everyone is entitled to an opinion and there appear to be several.
Someone has probably said this before, but wouldn't the easiest option be to ask the supplier/manufacturer and get the definative answer.
OK, I'll get my coat!
John.
rayward
posted on 5/3/06 at 08:52 PM Reply With Quote
John.
toooooo easy, and no where near as much fun!!!!
jay taylor
posted on 5/3/06 at 09:00 PM Reply With Quote
it just makes it that little bit quicker for some people doing it this way for now i can attach everything first thing tomorrow morning instead of waiting till tomorrow to speak to the supplier i also find it good to see other peoples opinions who may have had the same worries i have
skodaman
posted on 5/3/06 at 09:20 PM Reply With Quote
While we're on the topic where's the best place to buy? I'm after some for standard wishbones. Cheapest and Best if possible.
Skodaman
posted on 5/3/06 at 09:44 PM Reply With Quote
I've only seen standard size ones on MNR's site if you mean to replace the Triumph type bushes.
907
posted on 5/3/06 at 11:07 PM Reply With Quote
I bought enough eye tubes, crush tubes, & poly bushes, plus some spares, from Lolocost.
Then, measuring them carefully I tried to arrange them into sets.
I found I had 32 sets of 1
Good job I've got a lathe.
Paul G
JonBowden
posted on 6/3/06 at 08:28 AM Reply With Quote
I think this technical article at Sylva's web site should answer this
http://www.sylva.co.uk/technical/bolts.htm
(I know they are talking about rocker pivots, but I think the design of the joint is much the same)
Jon
andyace
posted on 6/3/06 at 09:43 AM Reply With Quote
Just done my GTS polys.
I superglued the polybush into the wishbone to 'discourage' it from spinning in the bone.
Packed the poluybush with moly grease and inserted the crush tube.
The crush tube sticks ever so slightly out of each end of the bush.
When tightened the crush tube is held solid in the bracket and the bush spins on the crush tube.
