posted on 11/3/06 at 09:42 PM |
ZX 14 Updates
For those interested, a few reports of the new ZX14
Part 1
Part 2
Just gotta wait for the engines to become available
alister667
posted on 11/3/06 at 10:01 PM |
Mmmm those clocks would look good in the middle of my dashboard........ And that grunt under my right foot!
http://members.lycos.co.uk/alister667/
zilspeed
posted on 11/3/06 at 10:03 PM |
Would this bit be a fly in the works - in terms of wiring it into a car ?
The electronics on this motorcycle utilize CAN (Controller Area Network) technology, which saves weight (by using fewer wires) and allows for a
greater volume of information delivered to the cockpit. In addition to all of the normal readouts (tachometer, speedometer, trip meters, and fuel
gauge), the ZX-14 provides a volume of information normally reserved for dedicated tourers, such as clock, water temperature, gear position indicator,
current MPG, average MPG, fuel mileage range, and battery voltage. It even offers adjustable shift rpm and launch rpm warning lights.
Possibly tricky ?
posted on 11/3/06 at 10:20 PM |
Where there's a will...................
stevec
posted on 11/3/06 at 10:52 PM |
Theres a relative!
[Edited on 11/3/06 by stevec]
yorkshire-engines
posted on 11/3/06 at 11:09 PM |
Zx14 engine kit
ok so who wants one let me know
Nick Skidmore
posted on 12/3/06 at 07:57 AM |
Isn't that CAN wiring the same stuff that turned certain Peugeots in to fire bombs?
Should be a good fire damaged market then??
cossey
posted on 12/3/06 at 09:13 AM |
can is used on almost every new car. it should be no worse than a current car engine to wire up. (plus it should allow easier plugging the ecu into a
computer to get all the measured parameters off.
GEORGE80
posted on 12/3/06 at 10:55 AM |
sounds like the engine will be a great in a bec, but horrible looking in bike form, looks out of proporsion, but hey everyone has different taste
alister667
posted on 12/3/06 at 11:11 AM |
I agree, if it is CANBUS then you'll be able to get all sorts of electronic goodies to plug into it a lot more easily.
