benson68
posted on 14/3/06 at 08:03 PM |
Pinto Sump Mod
Hi
I am a newbie here and no doubt this is my first post of hundreds to come
Does any body have the dimensions for a modified Pinto Sump please
emsfactory
posted on 14/3/06 at 08:28 PM |
Any dimension you like.![](/images//smilies/tongue.gif)
flak monkey
posted on 14/3/06 at 08:31 PM |
Very helpful ![](/images//smilies/tongue.gif)
You need to chop enough off so that the bottom of the sump is about level with the chassis rails. So it depends on your engine mounts. But at a guess
I would say somewhere around 30-40mm is about right...
I stand to be corrected though.
PS welcome to the site
Sera
http://www.motosera.com
muzchap
posted on 14/3/06 at 08:37 PM |
Check out www.rtmotorsport.co.uk
they used to do cheap sump mods
Drop the bloke an email
murray
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Mark Allanson
posted on 14/3/06 at 08:51 PM |
try this
Chippy
posted on 14/3/06 at 11:07 PM |
Only thing I would suggest that there is not much point in reducing the sump further than the lowest part of the clutch bell housing. If that makes
sence. imho. ATB Ray.
benson68
posted on 14/3/06 at 11:46 PM |
Thats great thanks
DarrenW
posted on 15/3/06 at 10:54 AM |
I followed Marks illustration. Worked a treat. Highly recommended if you want to do it yourself.
Sealing the welds with Mig is a pig to do but possible if you are half decent welder and patient.
pajsh
posted on 10/2/07 at 01:45 PM |
Thanks guys great work.
I like the second one (from RHOC) site IIRC but I will look at both and make my mind up.
The link to Mark's doesn't seem to work but I've had a kind offer for email so no problem.
Cheers.
Bu66er, posted on the wrong link!
[Edited on 10/2/07 by pajsh]
I used to be apathetic but now I just don't care.
