tom court
posted on 15/3/06 at 04:09 PM |
heeelp acewell speedo
can any body expain this wiring diagram to a simplton from dudley?
got power and rev counter working but can`t get the F*****G speedo to work. Text
![](/galpreviews/a339800-40600001.JPG) ![Rescued attachment 40600001.JPG](/gallery/a339800-40600001.JPG) Rescued attachment 40600001.JPG
flak monkey
posted on 15/3/06 at 04:15 PM |
Connect one side of the reed switch to the green wire, the other end to ground.
Should work then...
Sera
http://www.motosera.com
tom court
posted on 15/3/06 at 04:16 PM |
will try it cheers
tom court
posted on 15/3/06 at 04:17 PM |
what about the brown wire?
tom court
posted on 15/3/06 at 04:31 PM |
all working. i have a speedo first time
many many thanks
tom
posted on 15/3/06 at 04:35 PM |
Should work then...
not unless there is a magnet that comes near the reed switch. the magnet would be fitted on the rotating item, as it goes by, it closes the siwtche
that opens once it goes past. The open/close cylkces rpresent the speed of rotation.
flak monkey
posted on 15/3/06 at 05:27 PM |
Well i assumed he knew that!
Sera
