Author: Subject: Fitting Fuel sender... Hmmm
Krismc
posted on 18/3/06 at 07:19 PM Reply With Quote
hello does anyone know how to fit a fuel sender in a vortx without the need for rivnuts(as per spec sheet) ! and is this right 5 holes in sender and six on seal??
And if there is no other way is there someone in newcastle with a rivnut tool??
[Edited on 18/3/06 by Krismc]
piddy
posted on 18/3/06 at 08:16 PM Reply With Quote
I would say you have the wrong rubber seal.
stevebubs
posted on 18/3/06 at 09:58 PM Reply With Quote
So would I. There's 2 standards for the senders.
One has 5 holes and one has 6.
You've a mish mash kit of bits from both.
muzchap
posted on 19/3/06 at 01:01 AM Reply With Quote
Ok the gasket is no biggy - just make new holes for it - in between the other holes.
Is glue petrol reistant? Just a question?
If you cant use 'rivnuts' - I'd use - it also depends on how thick your tank is - you could get away with using SELF TAPPERS - if you are very, very, very gentle with them.
If you can wait though - hop on Ebay and get a Rivnut tool
Murray
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Krismc
posted on 19/3/06 at 10:36 AM Reply With Quote
cheers guys but didnt want to put glue in with the petrol- thats why i asked!!!
ill have a look on ebay if they are cheap enough!
Krismc
posted on 19/3/06 at 10:41 AM Reply With Quote
....£45 i dont know if i can justify for a tool that i wont use again???
plus ill need some inserts..
Winston Todge
posted on 19/3/06 at 11:08 AM Reply With Quote
Just as an aside Krism... It looks like you've owned some pretty nice cars in your time! Like the Audi especially.
What motor did the Brabus have? Power to weight?
You must be chuffed with those new all tubular chassis's They look so slick!
Good luck with the rest of the build bud.
Chris.
muzchap
posted on 19/3/06 at 11:38 AM Reply With Quote
Kris,
Try this link £22.00 + delivery - scroll down for the budget one.
You can put it back on Ebay once you have finished so shouldn't cost you too much in the end :p
But you say you'll only use once - I bet you'll use it a lot more ;-)
CLICK ME RIVNUT TOOL CLICK ME
Krismc
posted on 19/3/06 at 03:47 PM Reply With Quote
yea sold it to buy the brabus and the house
it is a 0.7litre turbo 101Bhp 750Kg ive still got it and its up for sale! good with the padel shift and rear wheel drive!
yea looks pretty darn cool all in tube- most is covered up in the end thought eh!
Chris.
and cheers mate ill need it- you have any build pictures
Krismc
posted on 19/3/06 at 03:48 PM Reply With Quote
yea and ill think ill buy one off them rivnut tools for that price!!
Daft Lad Picko
posted on 19/3/06 at 06:51 PM Reply With Quote
Can I add one thing, I had the 6 bolt model of the sender (to fit your seal), when you drill the holes, DO NOT presume all the mounting holes are equi-distant from each other. I drilled the holes using the seal as a template. When I offered the sender up, with the float arm pointing towards the middel of the tank, only 3 holes matched up. I quickly sorted this with much swearing, a can of stella and bute force and ignorance. Just a quick note to say be careful.
Neil
There are two prices....the real one and the one you tell the wife!
Krismc
posted on 19/3/06 at 08:59 PM Reply With Quote
thanks for that mate... cause i would have just drilled away.
and whats the best sort of sealer to use then.....????
Krismc
posted on 19/3/06 at 09:00 PM Reply With Quote
...ps and woo hoo my father in law has a rivnut tool
