tim windmill
posted on 19/3/06 at 07:29 PM |
etb digidash2 lite
just getting car ready for sva and have noticed that my digi dash is showing speed. rpm etc but the odometer is not recording the mileage just reads
000000
tried the digi dash in test mode and have ++ under the sp on constantly and when the car is moved forward and the magnets pass the speed sensor ++
illuminates under the rp. Am i right in thinking that the ++ under the sp should go on and off as the magents pass the sensor. any ideas
hope you can make sense of this post
nitram38
posted on 19/3/06 at 08:02 PM |
If your dash is recording speed then it must also record on the odometer. If it does not then it must be a faulty unit?
shortie
posted on 19/3/06 at 08:05 PM |
Tim,
Do you mean it shows speed when it's on the road being driven?
Rich.
tim windmill
posted on 19/3/06 at 08:35 PM |
yep, went up the road it shows speed when being driven and also shows rpm but when i got back odometer still reading zero.
oh no just had a thought maybe i have not covered a full mile as it was first time out and maybe the digi dash does not record tenths of miles
shortie
posted on 19/3/06 at 08:57 PM |
Could be right mate, not sure it does!
tim windmill
posted on 19/3/06 at 09:12 PM |
oh well looks like another illegal test drive![](/images//smilies/smile.gif) ![](/images//smilies/smile.gif)
MkIndy7
posted on 19/3/06 at 09:37 PM |
Could prove useful on a limited mileage insurance policy ![](/images//smilies/bigsmile.gif)
furyblade35
posted on 20/3/06 at 09:55 AM |
The DD2 displays to a resolution of 1 Mile or Km on the odometer display. 1/10th miles on the trip display. However it stores the distance covered to
a much higher accuracy in the internal memory. So you are not loosing anything.
Hope this helps.
The Test mode shows the ++ sign when the sensor is detects a trigger from the magnets or if fitted the bolt head sensor.
However, I believe there is a little bug in early versions of the test mode where the ++ signals are swapped from speed to RPM detect. Just give ETB a
ring if you have any problems!
Alistair.
