pk
posted on 20/3/06 at 01:30 PM |
Heater fan - choices!
Hello,I'm in the process of dreaming up a sutable de-mistiing system. Does anyone have any idea of a suitable heating system other than the
mini as these are getting to be rare in most scrap yards. If possible I'd like to fit just a fan at first followed up by a heater matrix, so a
suitable doner for a fan - any ideas?
iank
posted on 20/3/06 at 01:41 PM |
See this thread
http://www.locostbuilders.co.uk/viewthread.php?tid=39322
Polo heater looks good. I doubt a fan on it's own will pass SVA as a demisting device, but you could try a fan from a PC if you are going to
have a go (120mm, 92mm or 80mm are easy to get all are 12v) - try maplins if you want a new one.
stevebubs
posted on 20/3/06 at 02:53 PM |
Lots of mini heaters on fleabay. Going rate is around £15
Kissy
posted on 20/3/06 at 04:33 PM |
I have some nice, new ally bodied, flat axial fans, around the 80mm mark (will check), 12v, low current drain. Cover the P&P and a couple of quid
and you can have a couple. U2U me and I'll send the spec.
RazMan
posted on 20/3/06 at 04:57 PM |
I'm pretty sure you will need heat as well as a fan to satisfy Mr SVA.
CBS do a nice one but not exactly cheap.
Raz
iank
posted on 20/3/06 at 06:51 PM |
Other possibles (for demist only, not real heat):
Fine wire heated windscreen from Caterham
Here Costs best part of £300
Couple of 12v camping hairdryers
Here About £13 each (site only choosen as it was first on the list at google )
Pezza
posted on 20/3/06 at 08:58 PM |
Just wait till you've done the sva to fit the windscreen, the heaters are pretty useless in sevens anywayfor demisting i've found.
Plus you'll reduce weight a tad
graememk
posted on 20/3/06 at 09:53 PM |
i've got 2x of these for £30 from lolocost
MrSandMan
posted on 22/3/06 at 10:15 PM |
I keep looking at these but am not convinced. Anyone got them working. Any good??
