zxrlocost
posted on 23/3/06 at 09:38 AM |
best weight saving gainers
morning morning whats the best weight saving gainers on our 7's before it starts to cost 1000 pound to save a pound!
any chance of a little list or something
Im not bothered about saving loads as Id prefer to tune the engine
but obviously if something saves to me a good few kilos it seems a good deal
I know the wheels are one of the best but I like my team dynamics
ta chris
RazMan
posted on 23/3/06 at 09:40 AM |
Best one for me is to eat salads for a month ![](/images//smilies/wink.gif) ![](/images//smilies/bigsmile.gif)
Raz
graememk
posted on 23/3/06 at 09:44 AM |
take the passenger seat out, you know that once you have taken the mrs out she wont go near it again
zxrlocost
posted on 23/3/06 at 09:55 AM |
I must have a right weird missus then because she cant wait to drive it![](/images//smilies/bigsmile.gif)
scoop
posted on 23/3/06 at 10:14 AM |
Go for an ali floor and bulk head and cortina uprights rather than sierra. The unsprung weight makes a difference to handling. And of course the
engine. An old pinto is much heavier than say a zetec or a duratec and obviously much more than a bike engine. Then there's brake calipers,
discs and the amount of fluids on board...the list goes on![](/images//smilies/shocked.gif)
dave1888
posted on 23/3/06 at 10:37 AM |
Alloy bellhousing 6kg wieght saving, lightened flywheel although that can be costly.
JAG
posted on 23/3/06 at 10:41 AM |
Front calipers.
M16 = 5Kgs
Alu' 4 pot = 1.5kgs
For the pair you can save 7kgs for approx' £300.
Justin
JonBowden
posted on 23/3/06 at 10:47 AM |
Anything that rotates will give you a double weight saving - both linearly and rotationally.
So, lightening the flywheel, using light wheels (light tyres?)
Just noticed that you are using a bike engine - I think they already have light or non existant flywheels
[Edited on 23/3/06 by JonBowden]
Jon
posted on 23/3/06 at 10:52 AM |
remove the windscreen
remove the boot floor
zxrlocost
posted on 23/3/06 at 11:08 AM |
Ive got a bike engine and no windscreen already![](/images//smilies/bigsmile.gif)
smart51
posted on 23/3/06 at 11:16 AM |
13" wheels + tyres may weigh 16kg a set less than 15" Pick some up on eBay and sell your old ones. Might not cost much at all.
Solid front discs over vented. Save about 5kg, cost £100 - 150 maybe
Drive in your socks?
get a haircut?
G.Man
posted on 23/3/06 at 11:21 AM |
reduce the water capacity of cooling system...
light wheels, light uprights, light hubs...
diff with push in shafts, single strand loom, thinner body panels, smaller fuel tank, fibreglass seats with no upholstery...
Opinions are like backsides..
posted on 23/3/06 at 11:24 AM |
In my case, it's losing weight by dieting!
I've managed to get rid of 12kg so far, with 9 more to reach my target (in English, 2 stone lost, 1.5 to go).
Haven't noticed the car getting any faster, but now I can move quicker!
zxrlocost
posted on 23/3/06 at 11:29 AM |
ok cheers for the advice
gonna do celebrity detox![](/images//smilies/bigsmile.gif)
jos
posted on 23/3/06 at 12:10 PM |
Windscreen
Wipers
Heater
Expansion tank
Wheels/tyres
loose drums and fit calipers
Wilwoods/hispecs & discs
Interior trim carpets etc
Bellhousing
Boot box
Petty struts on roll bar
ChrisGamlin
posted on 23/3/06 at 12:39 PM |
As mentioned the wrong wheels/tyre combo is one of the easiest ways to add excessive weight, so keep them small and aim for under 12kgs a corner
overall (or 9kgs if you want 13" Barnby rims and ACB10s!), and the seats are another easy one, thickly padded armchairs will weigh 3-4 times
more than a GRP shell at ~4kgs and probably cost you more!
wildchild
posted on 23/3/06 at 12:54 PM |
go for the ariel atom approach and don't bother with panels?
on a more serous note, bike battery rather than car battery is probably worth a few kilos
G.Man
posted on 23/3/06 at 01:25 PM |
Oh good point, bought an aircraft battery at a show last year, donnington i think, and it was extremely light... they had another one that was
suitable for my cosworth engine and it was tiny compared to a stock car battery and the weight difference was incredible...
Think my current battery is like 1.2kg's or summat rediculous..
chrisf
posted on 23/3/06 at 01:44 PM |
I agree with ChrisG that seats are a great way to save some weight. The fully padded steel framed jobbies many use must weigh quite a bit. I used some
carbon Tillett seats and they weigh around 2lbs each. They really didn't cost as mush as one would suspect.
Thos Triton seats look like a great weight saver as well.
--Chris
Winston Todge
posted on 23/3/06 at 02:30 PM |
I thought drums were lighter than a disk setup?
Chris.
smart51
posted on 23/3/06 at 02:40 PM |
Chris.
there is about 0.5 kg per pair difference
Winston Todge
posted on 23/3/06 at 02:57 PM |
Ta smart but which is 0.5kg lighter? The drums?
PaulBuz
posted on 23/3/06 at 03:13 PM |
MT75 is 7kgs lighter than type 9 g/box
DURRRR!!!
Sorry just realised i'm in the BEC setion
[Edited on 23/3/06 by PaulBuz]
Paul
cossey
posted on 23/3/06 at 03:21 PM |
drums are lighter but if you get the vag rear calipers then they are lighter than stock drums.
ditch the reverse mechanism worth about 5-10kgs.
lighter propshaft, becs are lightet than cecs so can get away with a lighter prop.
push in shafts,
freelander diff (supposedly 8kg lighter but i dont believe it),
take all the excess junk out of the bike loom,
Chazzy
posted on 23/3/06 at 05:46 PM |
Having the confidence NOT to drive everywhhere with a tool kit capable of a roadside engine overhaul.
depending how you build/drive it it may get gradually lighter anyway
they're collectors cars...... you run along behind them collecting the bits.
