Dizzy_G
posted on 23/3/06 at 07:04 PM |
Project Assistance
Hi all,
I was directed over here from nefarious on PPC forum.
I'm looking for some help with a project. I'm to redesign an engine component using a ceramic.
What I’m looking for is drawings/dimension/part files of any of these components, Pistons, valves, lifters, cams & liners, if anyone is will to
share them. (if possible in Pro E format)
I have an engine myself from a gallant but it’s buried under loads of wood and it will probably be the summer before I see it again.
I do not have to make the parts, just redesign them and run FEA and thermal analysis on them.
I would really appreciate any assistance.
Regards
Paul.
Hope i have this in the right section
cossey
posted on 23/3/06 at 09:44 PM |
arent most ceramics far too brittle for use in engines (hence the cermic coatings on metal parts)
Dizzy_G
posted on 24/3/06 at 01:23 PM |
Most are but there are some ver fancy one available now.
Anyhow is that not part of the fun of the project, trying to redesign the components.
I had been think of doing a piston and using a forged alu insert to take most of the loading from the wrist pin.
I ahve not fully decided yet what i'm going to do but it looks liek there are no drawings to parts available.
jos
posted on 24/3/06 at 02:20 PM |
Why not speak to a local scrap yard and ask them for some piston heads, con rods other componets from a few different manufatcurers and then model
them using your own measurements.
Dizzy_G
posted on 25/3/06 at 08:25 AM |
thats what its going to come down to i think, problem is i have 5 other projects on the go and to be honest i don't really have the time. Was
just seeing if some would give me a dig out.
Thanks for the help guys.
P
theconrodkid
posted on 25/3/06 at 08:27 AM |
i belive cummins were working on a ceramic block some years ago
who cares who wins
pass the pork pies
Dizzy_G
posted on 25/3/06 at 05:37 PM |
There is a company who produce a fully ceramic rotary engine at the mo, fuel eff and emmission are supposed to be greatly improved.
Ceramic lifters are supposed to be quiet common in Diesel engines now too. In Trucks mostly from what i have found out.
