real viking
posted on 3/4/06 at 04:51 PM |
dampers/coilover
Hello everyone
In my global search after cheap and high quality dampers, i turn to you. Me and my locost build are located in sweden and the rumour says that UK is
the best place to buy dampers. Is there anyone who can recomend a person och company that sells what I´m looking for? Due to my taste for speed i´ve
shosen a heavy 2.0 litre engine as powerplant, therefor must the dampers handle a litle more weight than standard.
Grateful for all the help I can get
COREdevelopments
posted on 3/4/06 at 05:08 PM |
hi i got mine from a company called dampertech they do GAZ shocks think i paid £260 inc delivery for 4 coilovers adjustable of course. hope this helps
mark.s
posted on 3/4/06 at 06:17 PM |
hi
do you know what size you want??
pathfinder
posted on 3/4/06 at 06:26 PM |
There is a bloke on ebay.co.uk who sells GAZ dampers (without springs) for £180 may post to Sweden if you ask him nicely! Very good service and the
cheapest I found!!!
DIY Si
posted on 3/4/06 at 06:35 PM |
How much would a set of springs be to suit the ebay'd dampers?
jambo
posted on 3/4/06 at 09:23 PM |
a decent set of springs will cost about £110 including vat and dellivery.
jambo
posted on 3/4/06 at 09:27 PM |
to get the size you require set the front and rear at the ride height you want and measure bolt eye to bolt eye centres.
this is your mid way, so you will require roughly 2 inches either way this will give you your fully open/fully closed size.
(seven type cars)
Liam
posted on 3/4/06 at 09:52 PM |
I've always read that you want to aim for ride height being at 1/3 damper travel, so you get 2/3 travel in bump and 1/3 for droop.
Liam
kango
posted on 4/4/06 at 10:17 AM |
I wanted to post a question of "How to determine the shock lenth" As I have made my wishbones longer and moved he shock location
points.
What is the correct way to determine the shock length?
ned
posted on 4/4/06 at 10:53 AM |
measure the shock location length (ie bolt centre to centre) with the car at ride height (normally bottom wishbones horizontal/parallel to floor) and
then add on an inch or so for droop and make sure you have plenty of bump movement.
I'm having to change my front ally bodied protechs as i've gone from narrow to wide track
http://www.protechshocks.co.uk
not much more than gaz/avo/spax and ally bodied so lower unsprung weight
[Edited on 4/4/06 by ned]
beware, I've got yellow skin
