dern
posted on 4/4/06 at 11:59 AM |
Bones & trailing arms, CDS or ERW
Getting cracking on my build again and I'm wanting to order some steel for the bones and for the trailing arms (GTS dedion) and have been doing
a search for whether or not I need CDS or can use ERW which appears to be easier to get hold of (parkers sell ERW but don't seem to sell CDS or
at least I can't find it on their website) but have come to no conclusions.
So the question is which have you used for your bones and trailing arms?
Thanks,
Mark
R1 (2003 FI) powered Locost in progress
Fireblade/Impreza
flak monkey
posted on 4/4/06 at 12:04 PM |
The bones and trailing arms I have from GTS are ERW. AFAIK theres been no issues with them and Darren has them running on a few race cars around the
world...
Sera
http://www.motosera.com
dern
posted on 4/4/06 at 12:21 PM |
world...
That's good to know. You don't have to know the size of the tubing used do you? I'll email him and ask him if you
don't.
Regards,
Mark
[Edited on 4/4/06 by dern]
Fireblade/Impreza
flak monkey
posted on 4/4/06 at 12:56 PM |
I dont know the exact tubing sizes no, sorry.
The front wishbones are oval tubing and the trailing arms are 25mmOD round tube. Not a clue on wall thicknesses, sorry.
Sera
dern
posted on 4/4/06 at 01:02 PM |
Oval - eek, another
variable
Fireblade/Impreza
ecosse
posted on 4/4/06 at 05:01 PM |
ERW, as recommended by Flak monkey and others
25mm bone tube, 32mm bush tube, all 2mm thick
Alex
PS
I am not on the road yet so can't vouch for how strong they are ![](/images//smilies/shocked.gif) ![](/images//smilies/bigsmile.gif)
JB
posted on 4/4/06 at 05:34 PM |
Wishbone Tubes
I would always use CDS if you can get hold of it. The material will be a better / more consistent specification and without the seam will be
stronger.
There is no question that adequate wishbones can be made out of ERW, i would just make then larger to be on the safe side.
I started making wishbones fom DOM (this is welded tube that is then put through a drawing process like CDS, you struggle to see the seam in the
finished tube. Most better propshafts are made from DOM) and I had to squash the end a little to give a larger surface area to weld to. I heated the
ends and pressed them in a jig and the tube split.
I would not make wishbones from T45 or 4130 as it tends to snap rather than bend. Plus you need to know what to do regarding welding and heat
treatment (inc stress relieve)
John
mark chandler
posted on 4/4/06 at 06:22 PM |
I got some Landrover/ range rover steering rods, these are made of top quality metal and second hand cost pennies from a breaker.
You also get threaded ends for the TRE's and landrover TRE's fit cortina uprights so nothing else to buy.
The only thing is once welded you will need to clean/open the threads so will need to buy borrow a tap for this, I can loan one if required.
Regards Mark
Syd Bridge
posted on 5/4/06 at 08:40 AM |
I'll throw another in, not yet been mentioned.
DOM. Some tube advertised as CDS is actually DOM, some proper seamless. The DOM I use is much higher spec than ERW and CDS, and not much more
expensive.
Anything is suitable, as long as it has proper dimensions.
Minimum 22mm/7/8" with 2.5mm walls, put proper radii on the coilover plate on the front 'bones, and you should be safe for a long time.
Syd. ![](/images//smilies/smile.gif)
lexi
posted on 7/4/06 at 10:21 PM |
CDS which I made 1mm thicker than Book.
Alex
Marcus
posted on 8/4/06 at 08:16 AM |
I'd used CDS for bones and ERW for trailing arms if you're on a budget (and who isnt?)
Marcus
Marcus
Because kits are for girls!!
t.j.
posted on 8/4/06 at 08:46 AM |
I'm losing it! ERW,CDS,DOM etc
GB-standards are not ment for me!
I'm using "save-side" tube:
diameter 25mm
wall 3mm
FE 360
seamless
easely to work with, Grtz
