Author: Subject: vdo rev counter reading half speed
john_p_b
posted on 9/4/06 at 11:42 AM Reply With Quote
changed my ignition set up a couple of weeks back from points to electronic but there's still the good old coil there that the tacho connects to. sinse changing the coil and dizzy my tacho is now only reading half revs.
when i set my igintion the other night the timing light was reading 997rpm and the tacho was reading just under 500rpm so it's literally half!
any ideas as to why this is happening?
built a car, built a home, had a family. lost the family, lost the home, still got the car.
mandbsheldon
posted on 9/4/06 at 11:46 AM Reply With Quote
May be it's turning into a BEC
Leigh
Sorry nothing constructive to say
john_p_b
posted on 9/4/06 at 11:57 AM Reply With Quote
no such luck there leigh, i can get myself in enough trouble with the great lump of cast iron up the front so i think make it much faster and my dad would be getting his garage back and a spare room in the house
flak monkey
posted on 9/4/06 at 01:24 PM Reply With Quote
What tacho have you got John?
You might just need to change the number of pulses per revolution that the tacho is counting if possible. Its physically not changed obviously (assuming all 4 cylinders are firing...i.e. getting a spark) but for some reason your tacho isnt seeing the right number of pulses.
Sera
http://www.motosera.com
mookaloid
It might help if we knew what sort of ignition you have fitted
auzziejim
posted on 9/4/06 at 02:21 PM Reply With Quote
could it be anything to do with wasted spark?
john_p_b
posted on 9/4/06 at 03:27 PM Reply With Quote
it's a bestek electronic system.
the name of the type of distributor has completely gone from my head at the moment (need some sleep after last night) no points if that helps?!
before i just had coil and dizzy
now i've got coil, amp and dizzy.
it's a the gauge is from a vdo cockpit vision set 0 - 7000rpm
auzziejim
posted on 9/4/06 at 03:49 PM Reply With Quote
i would check if the bestek system runs a wasted spark system i believe that would cause a 50% reading on a tacho
Jon Ison
posted on 9/4/06 at 03:52 PM Reply With Quote
Wouldn't that make the tacho read higher though ?
posted on 9/4/06 at 04:30 PM Reply With Quote
Twice as many sparks . Do the VDO gauges need switches set to calibrate for type of ignition systems ? Sure my Greengauges have to
john_p_b
posted on 9/4/06 at 04:44 PM Reply With Quote
yeah the gauge has dip switches on it but they only vary between 4 - 6 - 8 cyl engines or for if it's running off a alternator (diesel engine)
the pick up for the tacho is still coming off the negative from the coil like it always has and there's no chance anything on the tacho has changed as i'd have to strip the dash back out to get at the switches on it.
vintagebuilder
Had exactly the same problem with my Greengauge tacho. It turned out that I had incorrectly set one of the switches to suit the correct Pinto ignition module.
Regards
john_p_b
posted on 9/4/06 at 04:47 PM Reply With Quote
why can i see me ending up pulling the dash back out
posted on 9/4/06 at 06:24 PM Reply With Quote
Can you not reach behind and release tacho fixings to allow tacho to come out and get to switches
john_p_b
posted on 9/4/06 at 07:12 PM Reply With Quote
paneled under the dash to make it look tidy.
if i take the battery tray/ scuttle out i'll get to it that way.
didnt take into account removing things when i fitted them. must be too used to working on renaults
Bob C
posted on 9/4/06 at 07:36 PM Reply With Quote
Hi John,
sounds weird to me. I had a (sort of) opposite problem when I went to electronic ign on my V8 - at low revs the tacho read high, but it "went right" at over 2500revs. I fixed this by splicing a low pass filter (RC) into the signal at the coil end. I guess the point I'm making is that it sounds as though it might have been reading wrong in the past, so was set wrong (2 wrongs making a right) & is now reading right, if you know what I mean.
However when the V8 was reading wrong the needle used to wander a bit... it was obviously not right!
Displaying too high revs was (for me) caused by the 'improved performance' (with the amp in) causing each spark to be noticed twice or more by the tacho - hence it thinking the revs were higher.
Another possibility is that the points system has goosed the tacho - but that doesn't sound very likely to me.
Best of luck!
Bob
john_p_b
posted on 9/4/06 at 08:11 PM Reply With Quote
the tacho always used to wander around 200rpm either side of what it was actually running, sinse the ignition change although it's only reading half engine speed it is extremely stable!
i always used to put it down to a earthing problem.
Bob C
posted on 9/4/06 at 10:00 PM Reply With Quote
Sounds like that might have been your problem then - now you just have to set the tacho up like it always should have been!!!!!
Bob
