Author: Subject: seats
jay taylor
posted on 10/4/06 at 07:25 PM Reply With Quote
seats
does anyone here think it is okay to cut and shut a seat from a sierra to fit
Triton
posted on 10/4/06 at 07:57 PM Reply With Quote
Lot of work not too mention heavy
www.tritonraceseats.com
www.hairyhedgehog.com
jay taylor
posted on 10/4/06 at 08:05 PM Reply With Quote
thought it would be just have an issue with money
i did see in a book about making seats out of plywood and foam but dont like the idea of plywood just
incase of water if you know what i mean
stevebubs
posted on 10/4/06 at 08:10 PM Reply With Quote
Ply will be ok if it's treated OK
Alternatively, ali / steel bent to shape
stevec
posted on 10/4/06 at 08:22 PM Reply With Quote
Go for the groovy Triton ones If you can, There good.
Steve.
[Edited on 10/4/06 by stevec]
Triton
posted on 10/4/06 at 08:37 PM Reply With Quote
If you going to use wood use marine ply.
stevebubs
posted on 10/4/06 at 08:57 PM Reply With Quote
TBH In a seven, you can probably get away with just 2 covered foam cushions per side - the ali / steel forming the cockpit will give it a firm base.
[Edited on 10/4/06 by stevebubs]
dave1888
posted on 10/4/06 at 10:07 PM Reply With Quote
I might have a try at the rorty ones see this thread/link
http://www.locostbuilders.co.uk/viewthread.php?tid=42489
Triton
posted on 11/4/06 at 08:00 AM Reply With Quote
Dave,
If you give up on the making your own front I do a seat that fits the Tiger Cat and it will miss that sierra bit in the floor. Somewhere I have pictures of a Tiger Cat fitted with some, the fella is up in Grantham If I remember right.
Mark
Marcus
posted on 11/4/06 at 08:09 AM Reply With Quote
The cut and shut seat method worked for me, I used Manta GT/E Recaro seats, took 1" from the middle of the passenger seat and 2" from the drivers. I only used the bases, and used Cavalier SRi rear seats for the backs (same material).
They are quite heavy though, and soak up water like a sponge
Marcus
Marcus
Because kits are for girls!!
