Mezzz
posted on 11/4/06 at 05:07 PM |
Donor Engine
I am looking at building a 750MC car.
Now if I get a 1600 MK2 I should be able to use every thing in that car to build the locost right?
Then if I get a 1300 engin and gear box that should work right, or if I get a MK2 1300 auto can I replace the gearbox with a manual?
Thanks JJM
auzziejim
posted on 11/4/06 at 05:32 PM |
all bar the front hubs, i think you will need cortina ones
the auto swap on an escort is simple i did it on my first mk2. you will need a manual pedal box, clutch, flywheel spigot bearing and the box
Mezzz
posted on 11/4/06 at 06:19 PM |
where would I get the fly wheel from and the clutch kit?
Humm this is looking like I will be making my life harder
auzziejim
posted on 11/4/06 at 06:23 PM |
ebay or i would suggest picking up a copy of classicford or retro ford magazines and searching the suppliers in there
Mezzz
posted on 11/4/06 at 06:42 PM |
How easy is it to do?
auzziejim
posted on 11/4/06 at 06:55 PM |
as you will have the engine out very simple. off with the sludgebox and torque converter, knock in the spigot bearing bolt on flywheel and clutch and
then bolt the box on.
