Mezzz
posted on 12/4/06 at 06:00 PM |
Just bought my Ford Escort MK 2!!!!
Well after a frustrating time looking for one i found a banged up old ford on ebay
It did not sell at the auction so I e mailed the chap and he is going to strip all the parts out of the car and give them to me all for £200 i am
thrilled.
Before I send him the list is there any thing that I should ask him to take out that the book dose not mention?
Here are a few pics.
![](/galpreviews/a354744-72_1_b.jpg) ![Rescued attachment 72_1_b.jpg](/gallery/a354744-72_1_b.jpg) Rescued attachment 72_1_b.jpg
Mezzz
posted on 12/4/06 at 06:01 PM |
Front
Mezzz
posted on 12/4/06 at 06:02 PM |
No here is the front
![](/galpreviews/a354746-34_1_b.jpg) ![Rescued attachment 34_1_b.jpg](/gallery/a354746-34_1_b.jpg) Rescued attachment 34_1_b.jpg
Mezzz
posted on 12/4/06 at 06:04 PM |
Here is a list of what I asked him to remove.... am I missing any thing?
The main items are as fowllows
engine (complete with carburettor, starter motor, water pump, inlet, exaust manfolds, gearbox, clutch including mounting brackets)
Rear axel (complete with break drums)
Propshaft and universal joints (should be section type)
Stearing Rack (including mounting clamp, track rods and swivel joints)
Wheels
Radiator (including conecting hose)
Master cylinder for break system
Windscreen washer system
Heater and fan unit
Exhaust pipe
Controls, cables and instruments
Clutch, break, and accelartor pedal box ( including plastic top hats brushes and pedal return springs)
Clutch cable
Speedometer cable
Choke cable
Handbreak lever (including mounting bracket)
Electrics
Alternator
Wiring loom
Starter motor solenoid
Ignition coil
Distributor
Horn
Horn relay
Fuse Box
Flasher unit for indicators
Fule tank sender unit
Break light switch
Other
Hoses and clips
Fule pipes and clips
Accelator cabe
![](/galpreviews/a354749-c4_1_b.jpg) ![Rescued attachment c4_1_b.jpg](/gallery/a354749-c4_1_b.jpg) Rescued attachment c4_1_b.jpg
flak monkey
posted on 12/4/06 at 06:14 PM |
Sounds like everything to me!
The bloke will only have a shell left after that lot! You might not need some of it if you are building a racer. And there are something i would
replace as a matter of course, (such as hoses and cables)
Sera
http://www.motosera.com
UncleFista
posted on 12/4/06 at 06:48 PM |
Front calipers ?
Tony Bond / UncleFista
RichardK
posted on 12/4/06 at 09:23 PM |
Steering column and steering wheel?
Avoneer
posted on 12/4/06 at 09:55 PM |
Front uprights are a must.
Pat...
wildchild
posted on 13/4/06 at 09:10 AM |
would it be easier to make a list of what you dont want? ie:
bodyshell
headlights
seats
interior trim
that's probably about it really!
dave-69isit
posted on 13/4/06 at 07:47 PM |
parts
is this car local to you
Mezzz
posted on 13/4/06 at 08:05 PM |
Its about 4h away thats why I am getting the parts as I dont have a traylor and the cost of getting it here would be to much so the guy offered to
strip it all for me how can I refuse
Avoneer
posted on 17/4/06 at 09:30 PM |
Can I have the front wheel studs if they are metric?
Pat...
