jeeby_man
posted on 17/4/06 at 10:24 AM |
design of pedal box
Hi
nearly finished designing my pedal box. just wanted to see what people think of it. it still needs abit of tweeking, but the main design work is
done
Image deleted by owner
cheers
Ian
[Edited on 17/4/06 by jeeby_man]
rayward
posted on 17/4/06 at 11:43 AM |
looks OK to me,
have you checked the accel/clutch pedals will give you enough cable travel with the pivot point where it is??.
Ray
TPG
posted on 17/4/06 at 12:07 PM |
I'd chose different colours......
..Which was nice..
hotshotbeans
posted on 4/5/06 at 04:44 PM |
very nice
very good if you are a midget ....me thinks pedals are to close with the giant padles
but very nice easy geomitry you have inspired me to rush out to my garage and make mine up now ive seen your design
thanx very much
well done
Dear God smashed the mold once he cast me realizing he really had done it this time!
Gav
posted on 4/5/06 at 06:53 PM |
How are you planning on getting a bolt through the brake pivot?
NS Dev
posted on 5/5/06 at 10:04 AM |
Yep, brake pivot will be a prob as will throttle (cable) travel unless you run a bellcrank in the linkage on the engine.
wildchild
posted on 5/5/06 at 10:47 AM |
How about shifting the brake pivot point forward a bit.
Will let you get the bolt in, and would also make it easier to rev match your downshifts under braking (as the pedal will then come back level with
the throttle pedal)
jeeby_man
posted on 5/5/06 at 06:23 PM |
the pics of the pedal i have posted is abit misleading due to the angle
the dimensions are based around an ap racing pedal box.
i'll hopefully make a start on them at the weekend, and i'm keeping my fingers crossedit will work
cheers
Ian
[Edited on 5/5/06 by jeeby_man]
