jim7
posted on 18/4/06 at 01:27 PM |
Sierra Steering
In process of sorting donor, all that I have found have got power steering. Realise rack is no good, but is rest of steering the same? enabling me to
use the column and links. Or is the non PAS column different? Looked in Manuals without success.
thanks
jim
omega0684
posted on 18/4/06 at 01:39 PM |
sierra column
the columns from the power steering sierra are fine to use, im using a column that is from a sierra with power steering (or it used to have power
steering ) i have changed the rack to an escort quick rack from 'Rally Design'(2.4 turn, from lock to lock) you will need to weld an
extention onto the column and get a couple of UJ's and an extension rod to connect to the steering rack. then you will also need steering rack
extensions(if you choose the escort rack) and track rod ends, then put it all together, easy, job done!
hope this helps
chalkdust
jim7
posted on 18/4/06 at 02:12 PM |
Thanks Chalkdust,
yes it helps a great deal, appreciate early response!
jim
