Author: Subject: TIM Gauges - Wiring Question
DickieB
posted on 19/4/06 at 06:06 PM Reply With Quote
I need to re-wire my TIM water temp gauge. It has 3 terminals on the back labelled - "S", "G" and "I" or "-" depending which way you look at it! Any ideas which is which please? Clearly one is +ve feed, one is earth, and the other is the sender.
Dickie
muzchap
posted on 19/4/06 at 06:14 PM Reply With Quote
Perhaps:
I = Ignition fed (live)
G = Ground
S = Sender
try it with a small 9v battery first - should move the gauge enough to test - without killing it..
[Edited on 19/4/06 by muzchap]
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
