davepro
posted on 21/4/06 at 02:47 PM |
Sierra/Cortina Stud Layout
Please can you advise whether the wheel stud layout is the same on the Sierra and Cortina front disk. Also can you use the Sierra XR4x4i disks on
Cortina Uprights.
Again, thanks in advance.
Dave
Dave Prouten
liam.mccaffrey
posted on 21/4/06 at 02:55 PM |
same stud pattern, not sure about xr 4x4 discs, aren't they vented? can't see a problem as long as caliper can be attached, not sure if
xr4x4 capiler bolts to the cortina upright though, and apparantly you're not supposed to split the m16 caliper to space it either
BUT
raldes sell a kit to do just that, so what do I know
[Edited on 21/4/06 by liam.mccaffrey]
Build Blog
Build Photo Album
garyo
posted on 21/4/06 at 03:08 PM |
The stud pattern for the wheels is the same, but on Cortinas the discs bolt to the back of the hubs - they don't get sandwiched between wheel
and upright like on most other cars, and this bolt pattern is a smaller pitch circle than the hubs.
So Sierra discs will fit over the Cortina wheel studs, but the discs will be in the wrong place for the caliper, unless, of course the Sierra uprights
are designed in the same way as the Cortinas?
Gary
liam.mccaffrey
posted on 21/4/06 at 03:14 PM |
apologies, tina hubs are the only ones i've ever taken apart
Build Blog
Build Photo Album
posted on 21/4/06 at 03:56 PM |
The easy way to get vented bigger discs with Cortina parts is to fit Capri 2.8 vented discs
