<<  1    2    3  >>
Author: Subject: has anyone had a go at fitting a st24, 2.5 v6 duratec into a seven style car? or can it not be done????
buncefm
posted on 24/4/06 at 03:52 PM Reply With Quote
posted on 24/4/06 at 04:00 PM Reply With Quote
Why when a BEC will outperform it?
mookaloid
posted on 24/4/06 at 04:03 PM Reply With Quote
soooo predictable
posted on 24/4/06 at 04:20 PM Reply With Quote
soooo predictable
DITTO
Danozeman
posted on 24/4/06 at 04:37 PM Reply With Quote
Didnt someone on here try it ages ago??
Dan
RazMan
posted on 24/4/06 at 05:02 PM Reply With Quote
I've got one in my middy ........... but that's probably no help at all
Raz
ady8077
posted on 24/4/06 at 05:05 PM Reply With Quote
Hi
Dont no of any sevens, but Chris Hill has fitted one in a Stylus
Have a look in the members car section here http://www.clubstylus.be/
Adrian
garyo
posted on 24/4/06 at 05:31 PM Reply With Quote
I'd like to, but have been talked out of it because of the weight. Gone for a Series 3 zetec on throttle bodies instead.
bilbo
posted on 24/4/06 at 05:43 PM Reply With Quote
This is my first choice of engine, but I haven't yet confirmed if it will be possible. It's certainly not going to be the lightest option (nor is it that heavy being all alloy), but 200bhp + should be possible without any serious work, cheap to buy as there are loads around and it will sound glorious
Mating it with a RWD gearbox will certainly be an issue as I'm yet to get a definitive answer on what the bolt pattern is etc. Also the book chassis will need tweaking for it to fit, but we'll see.
As I'm planning a tourer rather than an out and out blaster, then I think it will be a pretty good option if I can get it to work.
[Edited on 24/4/06 by bilbo]
buncefm
posted on 24/4/06 at 07:03 PM Reply With Quote
whats a BEC then? im pretty new to all this so you'll have to bare with me, i've got the origanal 1300 x-flow from the escort at the mo, still not finished it so don't know what it runs like.
garyo
posted on 24/4/06 at 07:12 PM Reply With Quote
Have you weighed one? I'd be interested in a like for like comparison with a Zetec.
Gary
Marcus
posted on 24/4/06 at 07:19 PM Reply With Quote
Oooh Buncefm, you are new around here aren't you
BEC - Bike engined Car.
Some people swear by 'em, some people swear at 'em!
Either way you ain't going to get more performance for your money. Even a standard fireblade engined seven is capable of a 4sec 0 - 60 sprint.
Good luck on whatever you go with and welcome to the best forum on the 'net
Marcus
Marcus
Because kits are for girls!!
buncefm
posted on 24/4/06 at 07:23 PM Reply With Quote
Marcus
cheers marcus, thanks for updating me with the abbrieviations
ive thought about the BEC's how do you go about the gear box? what can be used and what sort of money can you pick one up for? i have heard that they are best used on the track and aren't that good at low rpm?
RazMan
posted on 24/4/06 at 07:37 PM Reply With Quote
205 Kg according to this flyer
Raz
RazMan
posted on 24/4/06 at 07:43 PM Reply With Quote
I estimate that my ST24 will be making more like 220bhp with a decent exhaust, intake and ignition map. A little whiff of gas for that 'special occasion' will spice it up to nearly 300bhp which makes the power to weight ratio (700kg for my middy) quite interesting to say the least!
Raz
andyd
It's built onto the bike engine. You get an adaptor to fit on instead of the front sprocket and attach a prop shaft to that. Eh voila.
NigeEss
posted on 24/4/06 at 07:48 PM Reply With Quote
Welcome Buncefm,
BECs used the bike gearbox with a propshaft adapter where the drive
sprocket lives. Thus giving a sequential box. Obviously there's no reverse but
there are ways to fit one in the drivetrain.
Most don't bother as becs weigh so little, just push
As for price, well how long is a piece of string !
I paid £300 for a ZZR1100 and some pay £3000 for something like a Hayabusa.
Some say becs are more suited to tracks but it's personal opinion at the end of the day.
Nige
Tim 45
posted on 24/4/06 at 07:52 PM Reply With Quote
Are you sure 205kg, that sounds a lot compared with the normal Duratec (straight 4) at 95kg. I would have thought that it would be heavier but not more than twice!
bilbo
posted on 24/4/06 at 07:54 PM Reply With Quote
Ouch That's twice the weight of a Duratec HE (109Kg)
Perhaps I should be thinking again?
Does anyone know the weight of a Zetec, or for that matter a Pinto?
Tim 45
posted on 24/4/06 at 08:02 PM Reply With Quote
Duratec HE is about 95 dry
Pinto IIRC is about 150, boat anchor would be lighter TBH but is cheap power
Zetec about 20kg lighter
And well the XE is off the scales
[Edited on 24/4/06 by Tim 45]
RazMan
posted on 24/4/06 at 08:03 PM Reply With Quote
Yeah but think of all that torque - and the noise!
Raz
Tim 45
posted on 24/4/06 at 08:08 PM Reply With Quote
For all duratec data see here
Liam
posted on 24/4/06 at 08:11 PM Reply With Quote
Bear in mind that from the pictures that weight looks to include flywheel, exhaust manifolds and cats, big alternator, power steering pump or ac compressor, beauty covers and maybe even engine mounts. Doubt some of the duratec quotes are that fully dressed. There will be plenty you can junk of that V6 for sure.
By way of comparison, i put my honda V6 in my car the other week and slipped my precision load cell between the hoist and straps. 126kg including my steel adaptor plate and the starter motor. I was pleasantly surprised. I still have to add a fabbed inlet plenum and a baby alternator but that's pinto territory with about 200bhp on megasquirt!! And about 300 when i strap on two little snails
Liam
tks
posted on 24/4/06 at 08:12 PM Reply With Quote
BEC
900cc bike engine
150Bhp 70Kgs INCL GEARBOX AND CLUTCH...
Tks
Tim 45
posted on 24/4/06 at 08:18 PM Reply With Quote
Duratec 150kg MAX inc gearbox (yes its true, i have seen it weighed)
Easy 200, possible 260bhp
car weight 580kg WET
power to weight roughly 448 bhp/tonne
Smiles all round
2.5 V6 data here
<<  1    2    3  >>
