omega 24 v6
posted on 6/5/06 at 03:39 PM |
Workshop floor
My shed floor seems to be breaking up, possibly as a result of poor mixture concrete, or overfloating of the wet mix bringing all the cement to the
surface.
It does not get very heavy traffic/use but a lot of dust is arising from this problem.
Is there a product that I could mix and pour onto the surface to relevel(gm) the area and seal it against dust at the same time?
A cheap method preferably folks![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
907
posted on 6/5/06 at 03:52 PM |
Floor leveling compound?
Very hard, very smooth result.
It involves hoovering surface, and soak with water/pva mix.
Mix flc powder with water and float on while pva is still wet.
hth
Paul G
omega 24 v6
posted on 6/5/06 at 05:42 PM |
Thanks. Any idea of a trade name for it. How long does it take to dry/set. The floor is mega powdery will pva/water mix be enough?
posted on 6/5/06 at 05:47 PM |
Cempolay is floor levelling compound but it's not very hardwearing and is best used under matting or something.
omega0684
posted on 6/5/06 at 07:25 PM |
i have a few bags you can have if you want to come and pick them up! self leveling compound that is
sorry i just checked where you live and you are about 500 miles from where i live, im sure B&Q sell it
ATB Anyway, good luck
P.S, when i did my garage floor i put concrete down first the a sealent and then self levelling on top, and then sealed that aswell, then laminated
and then carpet on top of that! i got all of it for free
[Edited on 6/5/06 by omega0684]
lexi
posted on 6/5/06 at 09:38 PM |
Overtrowelling will bring the aggregate and water to the surface and leave the cement at the bottom causing the perishing of your surface. Either that
or its been caught with frost when curing. Can you get down to any solid level with it?. Most screeding in bags is for levelling before tilework. You
could make your own as you got nothing to lose. Once you get the loose stuff try to ascertain what thickness of sreed you are gonna be able to put
down. Door openings and how much you have taken off will determine this. If your minimum thickness is 4mm at one poiny of floor and you have infills
of much more at other points your cheapest option is to screed the whole floor with 3parts concrete or sharp sand to one part blue circle orninary
portland cement. you should get 5 litres of pva b&q red container. Mix 50/ 50 with water and mix in some dry cement to very thin pancake mix. This
is your primer adhesive which you brush on with fine sweeping brush and then trowel sand cement mix on top while primer is still wet. sand and cement
should be well mixed to about consistency of bricklaying mortar. You can do sections at a timeand use the bonding agent to overlap your hard sections
from night before. Also if doing in sections feather the edges where you will join and put screed down with a quick trowel and give another trowel
when your fingers hardly make a print.........That`s the Locost way to do it
Alex
