flak monkey
posted on 9/5/06 at 02:41 PM |
Weber DCOE Carb Linkages
Hey guys,
Got some DCOE carbs on their way, just been having a look at the linkages for them.
Has anyone used the twin cable linkage? if so what cunning method did you use to attach the cables to your accelerator pedal?
Sera
http://www.motosera.com
stevebubs
posted on 9/5/06 at 03:01 PM |
my linkage came with 2 cables and a cunning part to attach to the top of the pedal which enabled it to have 2 cables attached.
Probably still got it around if I have a hunt....U2U me if you need it.
alternatively, I got my linkage from eurocarb in Reading - I'm sure they'll be able to supply one.
[Edited on 9/5/06 by stevebubs]
flak monkey
posted on 9/5/06 at 03:09 PM |
Ahh yes, but i have floor mounted pedals. Will probably have to make up a linkage for it I think.
I managed to get a new linkage for £30, but its the dual cable one.
Sera
andyharding
posted on 9/5/06 at 03:45 PM |
Just use one cable?
jonno
posted on 9/5/06 at 05:13 PM |
quote: I managed to get a new linkage for £30, but its the dual cable one.
where from, ebay ?, i'm kinda after one as well
tractorboy
posted on 9/5/06 at 05:16 PM |
im a bit confused as to how yours are linked . i dont know whether it is just because mine are older but i have just one accelerator cable which picks
up both carbs. cheers scott
flak monkey
posted on 9/5/06 at 05:19 PM |
Jonno you have U2U.
Is it ok to only connect one cable on a twin cable system? Might be able to knock up a single cable adapter actually
Sera
Deckman001
posted on 9/5/06 at 05:24 PM |
DCOE's ?? DHLA's are better
Jason
flak monkey
posted on 9/5/06 at 06:48 PM |
Hi Dave,
One that fits to the top of the carbs. Hoping it will fit under the bonnet as the GTS bodywork is higher than std. Sure I have seen other people with
top mounted linkages. If it wont fit then I will just have to find a bottom mount linkage or something.
The linkage isnt very tall, about 2".
Sera
