Author: Subject: TIE ROD WOT THREAD ?
lenny
posted on 19/5/06 at 02:12 PM Reply With Quote
Hi all wot is the thread size on steering rack to tie rod (ford ) need to cut and retap new quickrack Lenny
posted on 19/5/06 at 02:50 PM Reply With Quote
You can not tap new threads of the same size on the tie rods! The original threads are rolled rather than cut so the diameter of the tie rod will be too small for tapping.
Just FYI the Mk2 Escort used M14 threads, the Mk1 used an imperial fine thread (9/16 UNF maybe??)
lenny
posted on 19/5/06 at 03:54 PM Reply With Quote
the rack is full with and i need to cut the rack to468mm long and retap the end to take the tie rod
Marcus
posted on 19/5/06 at 04:13 PM Reply With Quote
If you need to shorten the rack, it should be done in the middle, ie shorten the rack gear and the casing. If not you'll get horrendous bump steer. The track rods need to be longer.
MK shorten sierra racks for their Indy AND supply extensions to get the track back.
Marcus
Marcus
Because kits are for girls!!
lenny
posted on 19/5/06 at 05:21 PM Reply With Quote
yes it is a MK rack but fitting a quick rack kit so rack a tad long
